Question about Zanussi ZWF1630 Front Load Washer
Mains light on .all other lights including display not on
My kenwood kfc60ss15 fridge freezer that was delivered today.
Contact the seller of the fridge, we are not them.
Nov 22, 2016 | Cars & Trucks
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Flashing green led light in back of tower
hi, okay you got to be careful here, it's sounds like the power supply has called it a day, disconnect from the mains take the side panel off and get sniffling can you smell a burn smell , no , now pull the power leads from the hard disk and DVD drive if fitted now removing anything that could cause a short on the board , turn it on, do you get video display ?
Please be careful of static shock and mains shock so only look inside once it disconnected from the mains.
Keep me updated please.
Regards
Dec 21, 2012 | Computers & Internet
Advent 4213 not starting
check if it works with a external monitor, then ur display system has gone wrong
Aug 01, 2012 | Advent Netbook
Green light in bottom left on when device plugged in the mains, but cannot be switched off and no display
The green light indicates the unit is plugged into a active power supply and is charging.
Dec 03, 2009 | Tomtom GO 700 GPS Receiver
Mains switch on
some shortage inside the computer, go for technical assistace from qualified technician
Nov 04, 2008 | Dell Latitude D600 Notebook
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
No display
check the power cable, whether pluged well or not remove the monitor cable which is connected to your CPU only pluged the power cable and watch the LED status and let me know
Oct 10, 2007 | Proview PS 720F-1s (Silver, Steel Blue) 17...
Open Questions:
Zanussi ZWF1630 Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
