Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
F13 error ,saying washing machine is blocked ??
3 Suggested Answers
  • 1294 Answers
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Posted on Sep 03, 2007
SOURCE: washing machine says its blocked
take the block off it and it wil work just fine.
Posted on May 14, 2008
My Kenmore elite he3 says f13 and doesnt fill up with water at all
The F13 indicates a problem with the dispenser motor.
From the description you give it would seem there is something wrong with the intake valve. You say no water comes past the flowmeter.
The F13 error indicates a problem with the dispenser motor. This might cause the water for the detergent to end up in the bleach compartment but there should still be water.
From the description you give it would seem the water valve is the problem.
The image below shows how to enter and run the diagnostic test. At C:01 cold water should be dispensed. At C:02 the dispenser motor should move. Per the error code this may not happen but you should at least get cold water at C:01 in the test.
The valves can be checked with a meter is one is available. Make sure the water supply is turned on.
If there was not water then you should see an FH error instead of the F13 error code.
Try to run the test and see if you can confirm the inlet valve will actually work.
Use caution running the test with the top off
Jan 11, 2017 | Kenmore Washing Machines
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Bauknecht wae8999 washer machine error codes f13
F 13 is a water distribution problem ... poss filter blocked ..
Oct 02, 2014 | Washing Machines
Error code F13 Bauknecht washer front loading
error codes washer machine bauknecht f13
Nov 15, 2011 | Washing Machines
I have a F13 fault that wont reset on a AWOE9759. I do not know what a F13 fault is but i have tried what it says to do in the manual. Please help.
F13 Error = Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Replace failed component.
Dec 26, 2010 | Whirlpool Washing Machines
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Got a whirlpool washing machine the door wont open and on the display it says f13
f13 is a Dispenser circuit error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool washing machine keeps saying f13 whats wrong and how do i fix it
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Machine fault code "f13"
Sep 02, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
