Question about Canon imagePROGRAF iPF6300 Large Format Color Printer
Power supply ipf6300 fail - Canon imagePROGRAF iPF6300 Large Format Color Printer
Error 03130031-2618 in canon ipf 750
Error code 03130031-2618 is a voltage error. It could happens on these printers models: IPF6350, IPF6300, IPF6000, IPF8000, IPF8300, etc...
Solution 1:
  • Power off the printer.
  • Disconnect the power cable
  • Wait for 30 minutes.
  • Connect the power cable
  • Power on
Solution 2:
  • Check the power supply
Solution 3: The voltage of the print head is abnormal.
  • Replace the Printhead
Solution 4: Check for the cable continuity between the carriage relay PCB and the main controller PCB
  • Replace the cable.
    Replace the carriage relay PCB.
  • Replace the main controller PCB
Oct 26, 2017 | Canon Office Equipment & Supplies
IPF6300 printer has error codes 03010000-200C and 03010000-201A, what do these codes mean?
Hi Terry Thompson, I want to help you with your question, but I need more information from you. Can you please Call +1(518)348-9393 Thank You
Nov 12, 2016 | PRINTER Office Equipment & Supplies
Hi Terry Thompson, I want to help you with your question, but I need more information from you. Can you Call +1(518)348-9393 we will be glad to assist you Thank you
Printing blank pages ipf6300
Hello, can you give me more details? The ink cartridges have ink, if not replace with new ones? Is the print head expired, replace it. Take note: if you hwant to replace the printhead your cartridges need to be al 90% full.
Feb 11, 2014 | Canon imagePROGRAF iPF6300 Large Format...
Blank pages when printing ipf6300
A ink cartridge or cartridges maybe low, empty or possibly clogged
First step is to see will if it print a test page
Go to Start, settings, printers. Right click on the printer, properties, print test page.
If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
If the ink cartridge is still clogged, saturate a q-tip with alcohol
and lightly rub the print head
If there is still nothing after that then either it's badly clogged, low or out of ink, and needs to be replaced
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Printer Support
Reset ink counter ipf6300
first you must follow the step:
1. open cover ink
2. then follow the massage from the display panel
3. untill the information select displayed on the display panel
4. select oke if you want to change original ink to refiill
then on display shown the non ink chek status.
Apr 06, 2013 | Canon imagePROGRAF iPF6300 Large Format...
Canon ipf 6300
Circuit board problem, call Tech support
Mar 12, 2013 | Canon imagePROGRAF iPF6300 Large Format...
I have a canon IPF6300 large format printer and it is coming up with error code 03130031-2618
This code indicates a print head failure. First try replacing the Print Head, if however the problem persists things get substantially more complicated. Unless you are very techie it would be best to call a technician as further steps involve re-seating all the cabling to the Relay PCB and the Carriage Unit PCB. See more here.
Sep 17, 2012 | Canon imagePROGRAF iPF6300 Large Format...
Canon imagePROGRAF iPF6300 Large Format Color Printer Logo
47 people viewed this question
old marine
old marine
