Question about Brother LX3125 Sewing Machine
Brother ps 31 tension control not working
Lost manual need help to set tension properly
  • 2976 Answers
SOURCE: Tension problems
It sounds like your bobbin tension is too loose. If your needle went into the spare between the looper and the flat tensioner, the plate might need replaced, or removed and unbent.
Posted on Jan 01, 2009
yeroc
  • 397 Answers
SOURCE: what tension setting should I use for6 layers of
Depending on the thickness of fleece I would go back about 1-2 settings, being that your tension on bottom is already set correctly
Posted on Nov 30, 2009
Testimonial: "thanks!"
SOURCE: I have a Brother PS
The brother website has free operation manuals
On the home page,, on the left hand side down towards
The bottom look for PRODUCT MANUALS
Click on it & it will take you to another page where you can
Pick your model number & download the manual
Posted on Jan 20, 2011
Joe Onley
  • 363 Answers
SOURCE: Hi, I lost my manual for my Brother PS-33 (16
I went to the Brother site, (link below) follow the directions and insert relative information to receive information from the manufacturer.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
Hope it helps, good luck
Joe
Posted on Aug 29, 2011
SOURCE: NEED MANUAL FOR BROTHER XR 65
try the brother website
sewingpartsonline.com
sew4less.com
sewusa.com
ebay
a1sewingmachines.com
Posted on Apr 23, 2012
Settings on my brother Xr31 were moved and now it won't stitch properly
Consult the owner's manual for instructions on setting up the machine. The Troubleshooting section could also be helpful.
Make sure that you have cleaned and oiled your machine as instructed in the owner's manual.
Jan 14, 2016 | Brother XR-31 Mechanical Sewing Machine
sew4less.com
sewusa.com
ebay
Apr 22, 2012 | Brother Sewing Machines
Brother cs-80 tension issue
Remove the thread from the machine. Install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread. Set the upper tension to the midway point.
Insert the bobbin in the bobbin case (make sure it is turning the correct direction) and thread the bobbin tensioner. Install the bobbin case in the machine.
Insert the fabric under the presser foot. Lower the presser foot. While holding the top thread tail with your left hand, manually turn the handwheel (always toward you, never away!) one revolution until the top thread has pulled the bobbin thread up. Raise the presser foot and sweep both threads under the presser foot toward the back (you can use a stiletto, a pencil, or some other tool to sweep the threads). Lower the presser foot, gently hold both thread tails with your left hand and slowly turn the handwheel (either manually or by motor) to form a couple of stitches. Then let go of the thread tails and continue sewing.
If it continues to cause thread nests or you have other issues, then your machine may need service.
Apr 01, 2017 | Brother CS-80
Joe
Aug 29, 2011 | Brother PS-1250 Pacesetter
Brother ps 31 sewing machine manual. where can i download for free. needle not working properly.
This one for you ^____^
http://www.manualslib.com/products/Brother-Ps-3100-474242.html
Jul 12, 2011 | Brother LX3125 Sewing Machine
Tension on reverse side of fabric is too loose-
Set the tension back to the recommended setting (in manual). This is usually around 4.
Always thread the machine with the presser foot up as this allows the thread to properly "seat" into the tension control.
Mar 23, 2010 | Brother XL-5130 Mechanical Sewing Machine
Cant get my tension right on my brother sewing machine vx 877 can you help me
Thread the machine with the presser foot up and then adjust the tension to the setting you need - general purpose sewing thread is around 4.
Threading with the foot raised is important as this opens the tension control and allows the thread to properly seat into the mechanism.
When a sewing machine is threaded with the foot down, the tension is closed and the thread cannot enter as intended and the tension control has nothing to control.
If this does not help, the machine may need the the spring in the tension control replaced. You will have to search for parts on the Internet or check with a Brother dealer.
Mar 10, 2010 | Brother Sewing Machines
I'm getting loops on the surface of my fabric. I have rethreaded both upper and bobbin and played with the tension.
Set the tension according to the manual for your machine.
Raise the presser foot and re-thread the machine. It is important that the presser foot be up when threading as this opens the tension control and allows the thread to properly enter.
When you thread with the foot down, the tension is closed to the selected setting and the thread cannot enter.
Check the manual to be sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
Keep the machine maintained according to the manual.
If you do not have a manual, check the Brother website for a free download.
Mar 03, 2010 | Brother Sewing Machines
What tension setting should I use for6 layers of polar fleece on my brother PS 1800?
Nov 30, 2009 | Brother PS-1250 Pacesetter
How to adjust the thread
Here is the user manual from which I will quote
ftp://ftp.brother.ca/ENGLISH/SEWINGMACHINE/XR31-UG.pdf
Page 19 has how to adjust the tension of the thread
There should be dial to which you can turn to adjust up or down your tension , use a piece of scrap fabric to ensure it is set at the right tension that you need ..
The upper thread tenison wheel is located on the left side of the machine above the needle ( top/front of machine shown on their diagram of the machine as #5 )
Sep 17, 2008 | Brother XR-31 Mechanical Sewing Machine
Brother LX3125 Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
