Question about Dell Printers:Dell MFP Color Laser 3115cn
When printing there are small marks all over the paper
There's a small black "x" mark on every print on our Xerox C75 digital press.
The only thing I can think of is the IBT belt might have a mark on it. If the 'X' mark is in the same place on each print, regardless of size A3 or A4 then the problem is being printed intentionally e.g. within the file, if it's more random then it could be the belt. Is it only in the black, if so recheck the black drum. Is the mark on the edge of the paper it could be the cleaning system problem.
This is one problem that would need to be seen.
Good Luck.
May 27, 2015 | Xerox Office Equipment & Supplies
Align paper
This can be the result of a piece of paper (or similar) jammed in the printer - can be very small - and usually pulls the paper to one side. Another reason may be something on the roller (have you printed labels - especially part sheets?). Do you get regular marks on the printed paper?
Oct 07, 2013 | Canon MG5250 Printer
What paper feeder does the 4x6 photo paper go into to print a photo
Pull the paper out of the feeder tray. You will see small marks and a sliding plastic lever. use the picture to determine whether the photo paper is loaded face down or up and then slide the lever over until it hugs the photo paper snugly.
Mar 21, 2011 | Canon PIXMA iP3600 Photo Printer
The schiller at-1 ran out of paper, I put some more in. Now it will not print any suggetions?
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Nov 14, 2010 | Schiller Cardiovit At 1 Ecg Machine
The schiller At-2 we have in the office is acting up. Model number 021-02609. Office number is 480-889-0508. The paper feeds and doesn't stop were needed and the ECG being preformed on a patient are not...
HI,
ok
Oct 13, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
My DCP-165 has started taking more than one page at a time. This is not really a problem when printing single sided but when usign to print double sided it messes up the sequence. Any ideas
This is usually caused by the tray being incorrectly adjusted.
First remove the paper and check for curls on the end that was facing the rear of the tray. If the paper has curled, it was pushed too far into the tray.
There is a small tab inside the tray at the front that should be aligned with a mark that says "Ltr or Letter". There should actually be a little arrow on the tab pointing to an alignment mark what should say "Ltr or Letter". If it is pointed at something else, squeeze it to move it to the "Ltr" mark Once done, the paper should fit loosely in the tray without curling at either end.
Please note. SOME of these models have a tray that adjusts differently. In these models you can actually make the tray a little bigger by pulling it lengthwise. Consult your owners manual or down-load it from brother.com if you are unsure. In either case there will be two marks in the tray that you must line up correctly to make sure the tray is set for the correct size of paper. The marks should have LTR or Letter written beside one of them. If the tray is set too small it will jam the paper up into the feed slot. If the tray is set too large, the paper may not reach the pickup roller causing a "paper out" error. The paper should sit loosely in the tray with no more than 1/4 inch of space at each end of the paper.
Also make sure your paper is not stuck together with static. It helps to "fan" the paper like a deck of cards before putting it into the tray.
If this does not fix your double feed problem,
Sep 24, 2010 | Brother DCP 165C Compact Color Inkjet...
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
Black ink marks on prints from Epson R380!
Hello:
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
Susan
York, PA
smfree@comcast.net
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
My Brother Intellifax 2800will not print a fax. It says "Check Papoer-Reload paper by using llever - then press Fax Start." I do this then it says "Printing" and kicks on but then starts all over with...
is there a smug mark on the paper in the cassette. If there is then the feed roller needs to be cleaned ( alcohol ). If paper is out of the cassette & in to the delivery asm. then you have a small pice of paper stuck somewhere in the paper path ( hard to see if this is the prob. ) will need to dismatill the paper pathe asm. hope things work out.
C.W.H.
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
23 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
