Question about MSI K8MM-V Motherboard
Manual ms 7142 supoorted hdd - MSI K8MM-V Motherboard
map9966
  • 2351 Answers
SOURCE: I need to know the
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Posted on Jan 11, 2009
SOURCE: i want ms 7142 motherboard driver
Need drivers MSI MS-7142 VER:1 Need drivers MS-7142 VER:1 Hi All,
I need MS-7142 VER:1 motherboard drivers(audio, video,vga & disply)... (processor AMD)
i am using Windows-XP OS...
please send me the URL where will i download these drivers....
Thanks in advance...
regards,
salam mail : salamntm@gmail.com
Posted on Feb 20, 2009
  • 77 Answers
SOURCE: MS 7142 TO INCREASE RAM
hiya
its a case of purchasing the new ram modules taking the old ram out and popping the new ram in
i wud recommend using OCZ, GEIL or Crucial memory modules as these are the best makes
the spped of the ram varies from system to system depending on the system bus speed
the most common speeds for this board is pc2100, pc2700 and pc3200
these speeds are as follows pc2100 - ddr200
pc2700 - ddr333 and pc3200 - ddr400
hope this helps
Rik
Posted on Feb 27, 2009
SOURCE: ms-7142 ver:1 audio driver i want a free download
MS-7142 VER:1 Audio driver need processer AMD tm(64)
Posted on Mar 22, 2009
yourpc
  • 190 Answers
SOURCE: need of motherboard driver ms-7142
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Hope this helps...
Posted on Sep 21, 2009
Ms-7142 ver:1 audio driver i want a free download Ms-7142 ver:1 ni996 pleade give me audio driver
Hi there
This board is also known as K8MM-V.
If you go here:
Support For K8MM
Then you will find four tabs toward the bottom of the page, the second of which says Drivers. Clicking on this will give you a box further down which is a drop down menu to select your Operating System. Once you have done this there will be a list of all the drivers for this board and you can download whichever ones you want. You should note that this is quite an old board and it does not appear to support any OS above Vista 64bit as there are no drivers for Windows 7 or higher. Also with only 2Gb RAM maximum supported (according to the manual) I doubt its capability to run Win 7 or higher.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 10, 2014 | Computers & Internet
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
Dec 30, 2009 | MSI K8MM-V Motherboard
Need of motherboard driver ms-7142
Hope this helps...
Sep 19, 2009 | MSI K8MM-V Motherboard
I need MSI-ms-7142 ver:1 audio driver
i have no sound. So i need audio driver. Please send ms-7142 VER:1 audio driver
Jun 12, 2009 | MSI K8MM-V Motherboard
EMachine MS-7142 board pin connection diagram needed
easy !!!
this is the manual of your motherboard:
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
note that MS-7142 is actually K8MM-V (as you can see the filename of the manual is: M-7142.zip
Apr 20, 2009 | Computers & Internet
What is the maximum size of HDD supported on a mother board say MSI board say - K8MM-V (MS-7142) ? How do we detrmine this value ?
Dear sir,
i dont think there is any maximum size of HDD supported by any motherboard.....
But now a days 320 GB is the maximum size of HDD attached with any pc....
do reply
Abhinav
Jan 23, 2009 | MSI K8MM-V Motherboard
I've tried to find your driver but without results.. :/
better try some professional tool like this one: Driver Update Software for XP Vista 7 8
used it many times, and it's awesome.
wish you best of luck
Brian
Aug 04, 2008 | MSI K8MM-V Motherboard
How to connect ATX PWRSW to K8MM-V (MS-7142) board
You have a MSI mobo - goto the URL listed below, you will find everything there is to know about it there. Best.... PCrx4u
http://www.msicomputer.com/product/p_spec.asp?model=K8MM-V
Dec 29, 2007 | Computers & Internet
MSI K8MM-V Motherboard Logo
99 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
