Question about Bunn 10 Cup Home Coffee Brewer
Water wont heat but running light is going around and says it is heating water
My hot water light wont go out,my central heating wont come on either but I do have hot water
I'll need to know what make--model--- age of this unit is and if it's electronically controlled to help you----your question is too vague do to the enormous variety types of heating systems----I'm going under the info provided that this is a boiler with domestic hot water coil----you say central heating so this throws me off---do you heat with hot water--hydronic-----or forced hot air----if hydronic---it sounds like your circulator in not functioning----a bunch of reasons circulator has failed---aquastat's "circulator control" has failed---thermostat has failed----broken wires----plugged lines----it goes on and on----this is the best I can do with this info sorry Happy Rabbit
Apr 02, 2015 | Water Water Heaters
Great lakes hottub wont heat up
is the heat indicator light showing on the topside panel? If the pump is running and there is not enough water flow to activate the pressure switch then the heater will not come on.
If the filters are too dirty there may not be enough water flow to activate the pressure switch which sends the power to the heating element.
You just may have a bad heating element.
Jan 24, 2013 | Cars & Trucks
Electric bill doubled last month, and we've had the Powerstar AE125 tankless electric for over a year. There are no leaky faucets.
There are a lot of other things that eat electricity. Like space heater and using ovens for heat. Heat pump.Central heat fan running all the time. House lights left on. Outside flood lights. Clothes washer using HOT water. Look around real good. It all adds up. Also the power co. may be charging more for "fuel" costs surcharges. Here in GA I'm paying a bit more now to pay for a nuclear power plant.
Dec 26, 2011 | Bosch PowerStar AE125 AE125 Whole House...
The clean light wont go off making the dishwasher not run.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Mar 19, 2011 | GE Dishwashers
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Doesnt heat up
in a microwave, there is no heating element. There are microwaves that heat up the water molecules, they make them spin fast and that's what heats things up. Running it with nothing in it, you really can tell if it's not working by that test either, again, nothing to heat up. I would put in a cup of water, set on high for 3 minutes and it should boil, if not, get a new one for the price, why mess around?
Mar 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Temperature/heat wont work/dashboard lights on and off
It sounds to me like you're low on coolant. When you checked the coolant level, did you actually open the radiator cap and make sure the radiator is full? The plastic tank you generally add coolant too is actually an 'overflow' or 'reserve' tank. There is a hose that runs from that tank to the top of the radiator so if the radiator gets low on coolant, more coolant -should- run in from the overflow tank. However in practice this does not always work. I have a Jeep that leaks coolant and experiences this exact same problem. Coolant will not run from the reserve tank into the radiator because the hose is plugged up, and whenever the radiator gets low on coolant the temp gauge will go real high and then drop, and the heater doesn't work well. This is because the cooling system of your car is supposed to be a closed system, full of coolant and no air. When coolant leaks out, the space it used to occupy is now occupied by air, which does not transfer heat well. When 'air' is passing through your cooling system, no heat can be transferred from your engine to the heater and radiator, resulting in a hot engine and no heat at the heater. Then when a pocket of water passes through the system, the temperature gauge quickly falls as the water absorbs the heat from the engine. The hot water that cools the engine is where the heater gets it's heat from as well, so when water passes through the heater core, the heater works, but when it's filled with air, it doesn't.
Feb 12, 2009 | 2001 Pontiac Sunfire
I have water leaking from the engine, but don't know where from. The radiator has been changed the water tested for emmissions, pressure tested and still water is leaking. The heating blows hot when...
if you see the water leaking form the front side of the engine usually from the water pump since the pump is not running you also wont get heat, bit when you pressurise the sys you are forcing the hot water into the core and you have heat, it is the water pump.
Dec 04, 2008 | Honda Accord Cars & Trucks
Xbox wont turn on
RRD - Red ring of death, caused by the processor recieving to much heat.
Ebay.com sell tools to fix this but I am unable to gaurentee anything.
If its going around in a circle flashing then that is your problem.
The fix kits on the net run about 20 dollars and take 30-45 min to do..
and include instructions on how to use the toold, and place the new heat washers
heat silicon silver and how to put back together.
Youtube.com also has videos on how to repair.
Good luck
Sep 10, 2008 | Microsoft Xbox 360 Console
Bunn 10 Cup Home Coffee Brewer Logo
15 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
