Question about Samsung N145-JP01US Netbook
Factory reset MY COMPUTER IS SLOW HOW DO I REBOOT
How to factory reset a eee pc 1000HA
One way to clear an Asus PC of problems or viruses is to restore it to its original factory settings. This will wipe the computer clean and give you a fresh start. The idea of restoring your laptop may be intimidating, but there is no programming involved. In fact, these laptops are designed to be restored in a short period of time.
Step Turn off the Eee PC. Press the power button or select the shut down option from the computer's main desktop screen.
Step Turn the unit on and press the "F9" when the flash (logo) screen appears. A menu will appear with a list of options to choose from.
Step Select the "Restore Factory Settings" option from the bottom of the list in the menu and type "Yes" when prompted to verify the reset.
Step Press "Enter" when prompted by the computer to reboot the system. Wait a few seconds for the system to reboot.
Step Follow the prompts on screen to accept the licensing agreement and configure your settings.
Apr 24, 2017 | ASUS Computers & Internet
How to create a reboot disk? and how to reboot?
I you go to file hippo and down load a free program called ccleaner and then run the clean then the registry scan for issues but save the back up file. That should bring you back to good speed. also at file hippo malware bite is free also for a scan for malware which can slow your computer down. Hope this helps.
Mar 09, 2015 | Acer Aspire Computers & Internet
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiā„¢ Sync.
Dec 20, 2014 | Tablets & eReaders
We have a DSR500n router and we constantly have to reboot it as it starts to slow down everything lan and wan to a point we cannot connect to anything dure to timeouts. its new Any ideas on why would be...
If you have tried rebooting and that does not solve the issue, The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Jun 20, 2011 | D-Link Wireless N Services Router DSR500N
How to master reset my emachine desk top ? Its very slow
To do a factory resore and remove all data look at the boot up menue it will tell you to push a key generally F10 or F8 to start factory restore.
However you can fix your slow pc with out doing that by running the command "msconfig".
Go to "run" from the start menu
click run and type msconfig in it
next go to that startup tab and disable all.
next look for sound and video drivers (nvidia, ati)that may need to be on. and turn them on
(Things like adobe reader and ms office can be safely turned off and will still run fine)
now reboot you should have a mutch faster pc.
Don't forget to rate.
May 18, 2011 | E-Machines eMachines Desktop PC
My computer is slow and i want to restore it to the factory settings
To get at the recovery partition, reboot and hold down F9.
From there you can perform a system recovery from that partition if it exists.
May 09, 2011 | ASUS Eee PC 900 PC Notebook
The internet light is off all others green on the 5100 modem. Also, very slow internet and hard to go to various webpages. Will this correct itself over time or is there a quick fix?
You can try resetting the modem to factory condition.
Turn off the modem from power
Disconnect the modem from the computer
Turn on the modem
Press the reset button using a pointed object, (a toothpick or a pencil)
Wait for all the lights to flash green then release the button
Reboot your computer
Connect the modem to your computer
Everything should work fine.
If the problem persists contact the service provider.
Thank you for choosing Fixya
Oct 12, 2009 | Efficient Networks SpeedStream 5100 Modem
My netgear use to work very good, but now it is not working at high performance it is normally working at 54 mbps and my computer is very slow so how can i get my router to work at a high performance
reset it to factory and reconfig.some long not maintenanced routers have tendention to slow down untill they are reset to factory and reconfigured
Oct 04, 2009 | NetGear DGN2000-100NAS Router
How to reboot dell E173FP??
I assume you mean like a factory reset? Most Dells have a recovery partition, press the appropriate key when starting your computer (when the text goes across the black screen), it's usually F12. This should take you into 'recovery mode'. Then follow the prompts.
WARNING: IF DONE CORRECTLY THIS WILL ERASE ALL DATA FROM YOUR COMPUTER AND BE LIKE IT WAS WHEN YOU FIRST BROUGHT IT!
ENSURE BACKUPS FIRST!!
Jun 23, 2009 | Dell E173FP 17" LCD Monitor
I have an acer laptop and it is very slow i want to reset but dont know how how do i reset my computer
Pressing F8 Key during bootup, a black screen appears, listing some of the option with Load to Factory Setting/ Reset to Default.
Select that option and reboot.
Let me know if you face any difficulty, I will assist you further.
Best of Luck & Regards
Puneet
Oct 05, 2008 | Computers & Internet
Samsung N145-JP01US Netbook Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
