Question about Truper Professional Bolt Cutters 30"" Replacement Head
TRUPER BOLT CUTTER 30 , TOP BLADES DON'T COME TOGETHER WHEN CUTTING
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
I have clippers model number HC95WV. I can not get blades back together
Ok place the small metal cutter on top of the large metal comb, place the white plastic piece into the top of the cutter with the protruding bit at the back, place the metal bracket with 4 holes on top first locating the front into the white plastic slot, then place the last metal bracket on top with the raised part to the front, then simply hold it all together and put the screws in form the back!
Hope I got the right blade style!!
Mar 18, 2014 | Conair Health & Beauty
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Jan 16, 2013 | Cutter Tools
When cutting noodles they are coming out two noodles together? why?
Your blades are not completely set in their tension. You may have to replace the blades.
Nov 24, 2012 | KitchenAid Pasta Roller & Cutter Set...
Stihl hl75 pole trimmer. Blades don't move. Cable turns when cutting end is off machine, but will not drive blades when it is attached. Anyone have an idea as to what's going on?
More than likely a gearbox problem in the cutter head. They can break teeth on the gears and also have delicate needle bearings than can wear if they are ungreased. Maintenance is paramount on these moving parts.
Jul 26, 2012 | Stihl Hl75 Line Trimmer Owners Manual
I think that I over tightened the lock nut on one side (not using a tort wrench) after changing the mowing blades. I don't think it is cutting now. When I take the blades off from cutting, one blade...
there is a star shaped, or other, pattern on the bottom of the mandrel which fixes it into the blade. this has stripped so the blade is freewheeling on the mandrel. if you cannot remove the blade bolt, I think you are going to have to remove the deck and take it to a fabrication or machine shop to have them remove the blade from the mandrel. then you buy a new mandrel and a new blade, at a small engine repair shop, put it back together. take a picture of the top of the deck before you remove the deck belt so you know how to put it back on after you have the new mandrel bolted in. if it is old you may just want to replace all the mandrels while you are at it. they are less than 50 bucks each.
Aug 24, 2011 | Toro Garden
It's not cutting anymore, my husband greased it and cleaned it but it's not cutting, barely grazes the top. how do I know if the blades are sharp anymore. we have only used it 2-3 times on our cocker...
If you have another clipper, you can test the blades out on them to see if your blades are sharp. As for the blades not cutting on your clipper it could be a couple things. Your blade drive could be worn and not allowing the cutter blade to travel far enough each way to make a clean cut. Another thing to check is that your blade latch is not broken. This is the black hook by the blade drive on the clipper. If the blade latch is broke, the blade won't stay tight up on the clipper. Thus the blade will act like it is dull.
Mar 12, 2011 | Oster Golden A5 2-Speed Universal Motor...
I am trying to remove 4 blades from the Sprint 375 Rover mower. they are unmovable, have not been changed for a long time. Please help me!! I am in despair. Des
remove cutter disc from pto
hold blade in vise and weld the blade bolt head to blade on the grass cutting side using welder ( this transfers heat to threads and helps ) then undo nuts while still clamped in vise
repeat for other blades
always use new blades , bolts , nuts and washers
cheers pauly46
Sep 10, 2010 | Garden
Is the gear box on an old Woods Bush Hog packed in grease or a heavy weight gear oil and what type is best. How do you prevent leaking
90 weight only. Fill through top until level with side opening. If it is leaking, it has likely blown it's seals. If leak is slow, just keep checking and filling it. If it's just flowing out, it's best to replace the box. No too fun. I've had to do it twice in about 15 years. Hope this helps a little:)
Aug 19, 2010 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
Truper Professional Bolt Cutters 30"" Replacement Head Logo
616 people viewed this question
Top Truper Cutter Tools Experts
Kim Baker
Kim Baker
Level 1 Expert
Are you a Truper Cutter Tool Expert? Answer questions, earn points and help others
