Question about Truper Professional Bolt Cutters 30"" Replacement Head
THE CUTTER STAYS OPEN - Truper Professional Bolt Cutters 30"" Replacement Head
How long to roast 0.88kg pork leg?
1 hour at 350 deg or 175 c
Apr 29, 2016 | Ovens
The cutter on my White super lock 1934D has dropped down and won't stay in the correct position to cut. How do I fix this?
The cutter mechanism connects to the machine whet the front is closed. If you look at the machine with the door open. You will see a finger coming out of the inside of the machine. If you turn the hand wheel it should move up and down. On the cutter mechanism there is a fork that fits over the finger. When it is all closed up it sould work together to move the cutter blade up an down. Is the cutter in the up position?
Apr 29, 2015 | Sewing Machines
My l130 will not power the cutter
Check batter power is high enough to operate the electro magnet. Charger may not work if battery is very low and yellow light stays on. Check battery water level. Charge with external charger.
Jul 16, 2014 | John Deere L100 Series
Auto retract slice cutter slider that moves blade out will not latch. I have to hold it in place with my thumb and so can't make any cuts. Am I missing something?
If I am reading this correctly, your answer may be that the cutter is designed that way for safety. "Auto-retracting". You find it in some utility knives that often store employees are required to carry so they won't "hurt themselves". Annoying, really. Try buying another cutter that is not an "auto retract"-- or get used to using your thumb for the purpose of holding the slide so the blade stays exposed.
Mar 23, 2014 | Slice Ceramic Safety Cutter
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
OfficeMax (0M96431) Shredder\r\n ATTENTION LIGHT STAYS ON SOLID -... Answer Failed: retry attention light stays on solid - won't take paper in or go into reverse - have emptied bin, cleaned... (More)...
Have the unit serviced by a office machine technician. This sounds like there may be a problem in the gear drive, which you will not be able to access or repair.
Aug 14, 2010 | OfficeMax Office Equipment & Supplies
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Need part# for cutter assy
part# ACC-230kit Cutter assy for 1000 or 1000 II
Agson 856-751-9048
Oct 07, 2007 | Citizen CBM 1000 thermal Printer
Truper Professional Bolt Cutters 30"" Replacement Head Logo
544 people viewed this question
Top Truper Cutter Tools Experts
JOHN LAPIER
Are you a Truper Cutter Tool Expert? Answer questions, earn points and help others
