Question about IBM ThinkPad T30 2366 Notebook
BIOS password when I enter the IBM BIOS Setup Utility, to change the date and time settings, a lock appears and I need to put a password which I don't know.
  • 85 Answers
SOURCE: bios password ibm thinkpad g40
Sounds like you tried this, but it's worth a shot again. Remove the CMOS battery on the motherboard and let the laptop sit for an hour, then replace the battery with a new one.
If the only real issue is changing the time and date, you can do this in Windows and it will reset the BIOS clock, too, of course.
If the problem is that the time and date keep reseting, you either have a low CMOS battery or a short on the motherboard that is resetting it.
If all else fails, you might need to flash the BIOS from a floppy disk with the latest BIOS version for your machine to reset it and go from there.
PS: BIOS reset problems on laptops are sometimes due to power problems caused by battery packs going bad; check your battery pack, too, and see if it is working okay.
Good luck...
Posted on Nov 16, 2007
  • 84 Answers
SOURCE: IBM Thinkpad T23 2647 Power on password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Apr 29, 2009
sijudoniston
  • 134 Answers
SOURCE: IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Posted on Aug 27, 2009
  • 3278 Answers
SOURCE: Instructions say to use the Acess IBM button when
Hello, Salvador.
For most IBM system, select F11 at bootup to start the Product Recovery program.
Hope this helps.
Posted on Jul 18, 2010
  • 183 Answers
SOURCE: IBM Thinkpad T20 .when you press F1 for bios setup
you need to reset the bios, which means opening the machine up and starting up with the motherboard battery removed. then replace the battery and boot as normal.
Posted on Jul 25, 2010
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    Error 0271 : check date and time settings fan error how to fix this 2 error on IBM think pad 2647-2 TU, it display when turn on the power. thanks alot
    Easy way is to run the setup utility and clear the date and time - else go into BIOS and change the date and time to the correct ones. If it keeps reverting then you need to put a new battery in.
    Sep 17, 2010 | Computers & Internet
    IBM Windows 98 at start says computer is locked push button off and on. At first that would unlock it but now it doesn't even after turning on and off 10 times. Mande
    Try pulling the computer plug out of the wall outlet. Press the power maybe 20 times with the machine unplugged. Wait about 1/2 hour. When you power up the machine, be holding down the F1 key on the keyboard. A bios setup utility will appear.
    Look through those menus and find the item that allows locking: security, asset protection, tamper lock, password set with user selected, anything to with RFID; and disable it. Save the bios, and exit.
    It should work. Don't change anything you don't have to. And write down the existing values of the bios from the setup program. You can always put them back the way they were, and try something else. Change one thing at a time.
    Apr 21, 2010 | IBM Computers & Internet
    Lenovo thinkpad R51e , when i power on the laptop it show error code 271
    You need to set time and date in BIOS.
    Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
    Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
    Supervisor password
    A Supervisor password protects the system information stored in the BIOS. The user must enter the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to change the system configuration. If the Supervisor password is forgotten there is no way to reset it to enter the BIOS configuration. Setting a Supervisor password automatically sets the master Hard drive password. The following is the icon that comes up in the upper left corner if a Supervisor password is set:
    A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To regain access, the system will need to be serviced to have the system board and hard drive replaced. Proof of purchase is required, and this repair is not covered under the warranty.
    Document id: MIGR-59377 Last modified: 2005-06-17 Copyright © 2009 IBM Corporation Copyright © Lenovo 2009, all rights reserved
    Mar 25, 2009 | Lenovo ThinkPad R51
    My IBM Thinkpad is not switching on?
    The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
    The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
    Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
    Mar 15, 2009 | IBM ThinkPad T21 Notebook
    Ibm thinkpad r51
    What is the default password for my R51 Thinkpad by IBM Model # 2888?
    Feb 04, 2009 | IBM ThinkPad R51 Notebook
    Bios lock, ERROR CODE 0271
    Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
    Run BIOS Setup Utility to reset the time and date
    It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
    If you can get into the BIOS check the date and time settings and make sure they are correct.
    It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
    Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
    Feb 03, 2009 | IBM ThinkPad R52 Notebook
    Language Problem
    i have ibm netvista pc desktop im I want to install windows xp HDD so i went up to the BIOS, but the BIOS Language is Different, Not English, Japaneses Language, arching for BIOS Update, but i couldn't find, my machine model number . i was trying to boot the system by windows start up disk but it ddn't work also. Plz Help me,
    me,
    Feb 22, 2007 | IBM NetVista PC Desktop
    IBM ThinkPad T30 2366 Notebook Logo
    14 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
