Question about Drills
Makita Z1C-26 stopped hammering
Machine works perfectly except for no or very little hammer action
SOURCE: Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Posted on Oct 11, 2009
deme-tri
  • 90 Answers
SOURCE: I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Posted on Dec 03, 2009
rowdy45176
  • 2176 Answers
SOURCE: i have a makita hr300c rotary hammer drill.
it sounds like it needs new o rings and serviced. you can go to Makitatools.com and download a breakdown for this tool, If you are handy and take your time they are not that bad to repair. Let me know if you need more assistance.
Posted on Mar 21, 2010
rowdy45176
  • 2176 Answers
SOURCE: makita hammer drill hr 3000c has stopped
go to makitausa.com and you can download a parts schematic there, let me k now if you need more assistance.
Posted on Oct 07, 2011
jeffpetree
  • 36 Answers
SOURCE: Makita
possible broken spindle or gear in the gear case
Posted on Aug 29, 2012
I have a makita hr4011c rotary hammer drill, was working perfect then stopped, plugged into transformer but green light has come on on the drill but no action from the drill,
Did you check to see if the motor is even being energized.? If not check the switch. If yes, then check motor brushes.
Mar 29, 2017 | Makita Drills
Drill is not hammering
Makita have most cases a problem with the stroke bolt in front of the locking sleeve a broken ring that will blocked the stroke bolt.
In some cases the locking sleeve is also damaged , a rotary hammer is not made for demolition only a little small task but not for a long load , the metal pieces of the machine is no hard enough for long lasting .
Mar 10, 2014 | Makita Rotary Hammer - 240 RPM, 2150 BPM,...
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Aug 26, 2012 | Makita HR4041C 1-9/16" Spline Hammer
It wont hammer when I put a small or large amount of pressure on the hammer. It hammer only a short while when I start the mammer (about 1 second) and the same when I release the button.
Lack of hammering action usually indicates a lack of lubrication or worn piston orings. This hammer as well as many other makita hammers work with a piston moving forward and back within a cylinder. This piston moves a second piston within the cylinder with a pocket of air (pressure and vacuum). If there is a lack of lubrication or orings are worn, you will not get a good hammering action /force out of the second piston. Time for good cleaning and apply factory lube. Parts are at www.toolpartsdirect.com Good luck
Apr 12, 2011 | Makita HK1810 Power Scraper, Small,...
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Thanks.
Jul 28, 2009 | Drills
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Hammer switch jammed on Makita HP1621K/2 Percussion Drill 2
I looked at Makitausa.com website and it appears that you might be correct. there are 4 parts to this assembly and one of the problems might be the cam holder position #17. I would suggest that you go to their site and take a look at how the parts are supposed to be. I used the model number in the large header so this might not be the exact one that you have. Let me know and I will try and help further.
Feb 06, 2009 | Makita Drills
Drills Logo
324 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
