Question about Hobart Champion 4500 Ac Generator/Ac Welder #500491
Hobart champion 4500 generator runs but will not weld
2 Suggested Answers
  • 44 Answers
SOURCE: I have a Hobart Champion 4500 Ac Generator/Ac
try a different plug sometimes new plugs are no good
Posted on Sep 09, 2010
I am needing a carburetor rebuild kits. where can I found it
carburetor kits will be available from the engine manufacturer that is fitted to the genset ( so if honda go to a honda small engine place with the engine model )
go google and type in -- spares for hobart generator sets -- and there are pages available that will list catalogs or distributors for the parts
Oct 14, 2015 | Hobart Champion 4500 Ac Generator/Ac...
I have a hobart champion 4500, hard to strike an arc. what should i do?
Ensure your engine is in good running condition
The auto idle switch should function correctly
Remove the front cover of the welding generator, held by 2 1/4-20 screws
Behind that cover you will see a brush lock assembly, will have 2 wires connected at the top, one is insulated, one is not, mark the leads before you remove them to maintain correct polarity on the slip rings, the brush block is held in place by two Phillips screws, remove the screws, unplug the brush block,'remove it, check to see if the brushes move easily in the brush block, this is a common problem with these machines, the brushes tend to bind in the block, will not make proper contact against the slip rings.....
Remove the brushes from the holder, using a square of "scotch Brite" wipe the brushes, you may see a line around the brush, remove that by gentle cleaning, install the brush block, connect the leads, install the cover, go to work
Dec 15, 2011 | Hobart Champ 4500 Welder/Generator Outfit...
FLOODING CAN TURN FUEL VALVE NEARLY OFF AND WILL RUN ROUGH BUT NOT REALLY GOOD ENOUGH TO DO ANY WELDING
sounds like the float in the carburetor is stuck open. remove the float bowl and use a parts cleaner or carb cleaner and spray down the float and seat area, make sure that the float moves freely and the seat moves and seals properly.
c...
Jan 19, 2011 | Hobart Champion 4500 Ac Generator/Ac...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
May 24, 2009 | Hobart Welders Champion 500433A Factory...
Not generating power
The engine is not running the welding transformer. It may be a fuse, drive belt or gear wheel. Or the transformer is shorting out. Check these points in this order if the last one maybe you will have to replace the transformer. The transformer is 2 coils to stop them shorting out where normal electric wire is cover in plastic or rubber the coils are coated with enamel as are sum cooking pans. If this is damaged in any way it will short.
Apr 08, 2009 | Hobart Welders 500433 Champion? 10,000...
Won't idle down between welding
have you went to your local welding store? Praxair or airgas can call Hobart for the part you request,or they will call their Hobart salesman for you.
Mar 08, 2009 | Hobart Welders Champion 500433A Factory...
Hobart Champion 4500 Ac Generator/Ac Welder #500491 Logo
Top Hobart Electrical Supplies Experts
fred_therese
Trevor Turner
Bill Boyd
Are you a Hobart Electrical Supply Expert? Answer questions, earn points and help others
