Question about Sony STR-DA3300ES
Surround sound program fios remote to this receiver
I have a SONY digital receiver for surround sound I need universal remote codes rcu403d
Check Directv "Remote control programming" i have found some codes there. They have a search page for "universal remote codes." For different devices. Worth a try. Hope this helps.
Sep 30, 2014 | Audio Players & Recorders
1988 KAWASHO TV: Need remote control codes for VERIZON FIOS Remote Control
You may want to try a different universal remote, like the Logitech Harmony.
Apr 07, 2008 | Onkyo TX-SR605 Receiver
Codes for innovage universal remote to program it with my dish network box
Hi Gw, my name is Mike Houston a Social Media Representative at DISH. I understand you want to program your innvoage remote to our DISH receiver. When we send out our DISH receivers we will include our own DISH universal remotes that can control many different components like; HDTV, surround sound receivers and sound bars. We do not have the codes for other universal remotes to work with our system. I will provide you a link explaining in more detail on programming your remote: http://www.ehow.com/way_5501311_innovage-jumbo-universal-remote-instructions.html
Sep 01, 2012 | DISH Network ViP722 DTV Receiver /...
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
My samsung sound surround system is 1000watt and im not benefitting from the volume< it is connected to my tv but how do i turn the sound surround louder by using the volume on my tv aswell as the sound...
You need to program the TV remote to work the surround sound.  You gotta select a button that says AV or Aux on the remote.  Then you gotta input some #s so the TV remote can send the proper infrared beam to the surround receiver.  The codes will be in the users manual to operate different brands of electronics.
Oct 25, 2009 | Audio Players & Recorders
Remote comtrol
Depends on the make of your TV. Here is a link that shows, step by step, how to program your Fios without a code.
http://www.ehow.com/how_5066834_program-fios-remote-code.html
Sep 29, 2009 | Computers & Internet
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Verizon FIOS Motorola 6200-2 HD box remote freezes
i'm a verizon employee currently working at a customer's house. just swapped out 3rd 6200 stb, the channels will seemingly change on their own(scrolling) after pressing the remote just a few times. the root of the problem is that the remote is not responding to the stb in the first place properly. all i can figure is that there is some type of ir interference. i've placed the remote 1" from the stb and the same problem exists. it's not the box and the remote is brand new, tried 3 remotes as well. there is something going on in the atmosphere around the box - in or outside the custmer's house. they were on vacation and when they came back this is the trouble they were having. i don't have an answer, just some type of possibilities. there is a power transformer outside on a pole approx. 100' from the house and we had bad storm related issues in the past week. i know it's a stretch, but you never know. could be surround sound/ stereo equipment generating some kind of field??????????? good luck.
Apr 30, 2008 | Arris DCT6200 DTV Receiver
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Oct 24, 2007 | Onkyo TX-SR605 Receiver
Sony STR-DA3300ES Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
