Question about JBL Audio Players & Recorders
Trouble radio antenna
Antenna broken
Antenna relay switch
is it original antenna and radio? the antenna runs on a seperate switch oor goes up and down with radio on and off switch? if it is original stereo that is original chances are the antenna is broken and stuck in up position the mast may be purchased at dealership but motor may also be no good or not far behind. Listen at antenna for motor noise when radio is turned off if you hear the motor the plasic that drives it inside is broken.
Apr 02, 2013 | 2000 Cadillac Eldorado
My Saturn factory AM/FM radio on my 1996 SL gets some FM reception but no AM reception. I am trying to determine whether I need to repair the antenna or the radio.
You will need to pull the radio out of the dash and make sure the antenna is still pluged into the unit. If the antenna is in the windshield make sure the glass is not broken, and the wire broken. If there is an external antenn, you need to check the connection at the bottom of the antenna, and the wire is good between the antenna and the radio. Has any new items been mounted recently, the screws could have damaged the coax.
Rian
Aug 31, 2011 | 1996 Saturn SC
I have a Uniden 525 fixed mount 2-way VHF radio. It has power and picks up weather with the shakespeare antenna. However radio checks have failed and i don't receive anything either. The antenna's tip is...
Yes if the tip is broken, the antenna will receive, but not transmit properly. The make an antenna that has a 32" stainless steel antenna with a small metal "can". Can mount it anywhere.
Mar 28, 2011 | Uniden UM525 ES Series VHF Radio with...
Where can you purchase a replacement antenna for
I just replaced my broken antenna for my CFD-S350 by calling Sony Parts and Support at (239) 768-7691. Cost only $7.99 and that included the $2.00 shipping charge.
Jun 03, 2010 | Sony CFD-S350 Radio/Cassette/CD Boombox
Broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Feb 14, 2010 | Grundig Mini 300 AM/FM/SW Radio
Not able to transmit or recieve on cb radio in car
It could be your ant. a broken coax wire or a bad ground could cause this a could a broken or shorted wire on your mic.
Jun 02, 2009 | Maxon Radio Communications
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Surius Can not find antenna
A couple of possibilities all based on the assumption that the unit actually turns on.
1. Broken or disconnected antenna wire.
2. Broken antenna (The antenna is powered from the unit)
3. Broken unit.
Dec 27, 2007 | Sirius Satellite Radio Receiver
Cb radio
When you asy that you have an swr meter, you are refering to an inline meter, not the one on the radio, correct? Have you set the SWR by the instructions of the inline meter (if that is what you have)? Have you made sure the antenna is mounted to the bracket with the white plastic washer in between the antenna and the top of the bracket? You have checked the antenna coax for a broken center conductor and for a center conductor shorted to shield with a multimeter? Check antenna bracket to ground with a multimeter?
Dean
Rollin CBs
Oct 31, 2007 | Cherokee CBS2100 40-Channels Base CB Radio
22 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
