Question about Hotpoint Dishwashers
Hotpoint dishwasher model 7821 fills ok at start bt does not spray there is a regular noise as is something is stuck.Will empty and fil ok
catriver
  • 878 Answers
SOURCE: Stuck motor?
bert, to get to the sump and chopper assy. First remove the lower spray arm by holding the top tab and turning the spray arm off. Next grab a hold of the rear feed and turn it to the right until it unsnaps from the rear feed assy. Now you remove the filter and accumulator assy. It has torq screws, remove and lift off. Now the chopper cover will be on the left, one torq screw and it will lift off exposing the chopper blade. This is probably where it's jammed. Look at the attached pics. It will help you. Catriver.
Posted on Jun 16, 2007
Buffalo12980
  • 625 Answers
SOURCE: re: Maytag dishwasher
does the timer advance the control knob? check to see that nothing is in the way of the center spray tower. does it sound like any water is spraying around inside?
Posted on Sep 01, 2007
SOURCE: Empties and fills but boils the water
hi had the same problem, change the wash pump capacitor, you can get one from maplins
Posted on Jan 19, 2008
murdozzz2
  • 75 Answers
SOURCE: Siemens dishwasher not running.
hi there sounds like the wash pump has become ceased, isolate unit from power and remove left hand side panel the wash pump will will now be visible, gentle turn the induction cooling fan at the rear of the motor being careful not to damage the field windings then restart the prog.
Posted on Feb 29, 2008
SOURCE: hotpoint fdw85 dishwasher error code al10
Hi we've got the fdw80 and AL10 is the heating element. Ours goes wrong every couple of months luckyly we've got extended warranty till 2011. They wont replace machine as fixable so they will be coinng out every 2 months for the next 3 years.
Hope this helps
Posted on May 12, 2008
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
Water Inlet Valve
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 03, 2011 | Dishwashers
After filling and only when rinse commences a loud chattering noise begins. Somewhat like a circuit breaker making intermittent contact. It ends when I cancel and remains silent while the pump empties...
  • It sounds like you have an obstruction with upper or lower spray arm. check to see if the something is stuck in the path of the lower spray arm.
  • move the lower rack out
  • spin the spray arm by hand to see if it is hitting anything
  • if not .....spin the upper spray arm by hand under top shelf to see if it is hitting anything.
  • let me know how this works
Dec 30, 2010 | KitchenAid 24 in. KUDS25 Built-in...
DW fills and empties, but, in between the sprayer never comes on. There is absolutely no sound as the timer goes through the spray/wash cycle.
start the unit and open the door after abt 3 mins and look for water inside.if water is there and u dont hear water spray sound when running but only a low humming sound the motor is bad.if there is no water then chk for anything stuck under the water float.if that is ok then there is problem with fill valve.
Aug 17, 2009 | Dishwashers
There is a kind of grinding noise.
The most common reason for a grinding noise on an LG dishwasher is debris getting stuck (rather than ground up in the build in disposal.)
To resolve, remove the approximately 9 screws on the filter assembly in the sump area. You will need to remove the lower spray arm to get the filter out. Grab the spray arm and lift up and out.
Use a flashlight to inspect the entire area, especially in the rear area that has the valve that alternated sending water from the lower spray arm to the upper spray arms. I bet you fill find something lodged in there. Please be careful of broken glass as it can be almost invisible in water that remains in the sump area.
Please post back here what you find, OK?
Aug 06, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher doesn't spray water after filling?
could be a blocked pump or capacitor fault,check if pump armature will move(centre rotating part)you may be able to view end of pump with lamp,there may also be a slot for a screwdriver to move armature,you will feel if there is something stuck,hope this helps
May 27, 2009 | Whirlpool DUL300 XTL Built-in Dishwasher
Can you hear/see any washing sound/spray, it sounds to me like the wash pump could be faulty.
Nov 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
13 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
