Question about Ski-Doo Winter Sports
My 93 lynx surges while idiling. Almost shuts down but picks back up again.
Just purchased a 1993 arctic cat lynx. She runs really well but surges up and down while idiling. Could this be an airfilter or carb trouble?
ccrozier_agr
  • 36 Answers
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Posted on Nov 29, 2008
zr800o1le
  • 19 Answers
SOURCE: 2006 Arctic Cat ATV dies after about 15 minutes of riding
It Sounds like your Stator is going bad.
I would have it checked/Diagnosed by a Local Shop.
Posted on May 12, 2009
ImpalerCo
  • 13 Answers
SOURCE: Lawnmower starts but won't run-replaced airfilter and plug cleaned carb
If it is starting and not continuing to run it still sounds as though something is blocking the fuel flow. If the carb has been cleaned out, literally torn down and the needles cleaned so that no small debris is clogging them, check the fuel tank and lines for anything that could be restricting the flow to the engine. Remember that it's recommended that you replace the fuel line (cheap fix) when you dismantle the carb. Removing the line breaks off small pieces of the rubber in a worn line, which can re-block a freshly cleaned carb.
Posted on May 13, 2009
#1 Taper
  • 1040 Answers
Sounds as if the gas tank is not breathing properly. The next time you run it, when it's about to die, loosen the gas cap. It should begin to run again. This is a sure sign that your gas cap is clogged. Clear gas cap of debris, or buy a new one.
Jim
Posted on May 30, 2009
SOURCE: 93 convertible top wont go down
This happenrd to me the first few times after filling the tank. When the roof stops push the switch to up then back until movement stops then go back to down, eventually it will get rid of all the air in the system and the roof should start to work.
Posted on Jun 04, 2009
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Arctic cat troubleshooting
oil cooler is plugged go pressure wash it and clean it if that don't work cracked head
Aug 08, 2014 | Arctic Cat 2004 400 4x4
My 93 corolla stalls while driving, i can kill the
You may have a bad pick up coil in the distributor or a bad distributor. What also to look at is the throttle position sensor. That may have a dead spot it.
Aug 10, 2009 | 1993 Toyota Corolla
Jim
May 30, 2009 | Swisher Atv Tru Plow
May 12, 2009 | Sport & Outdoor - Others
Winter Sports Logo
22 people viewed this question
Top Ski-Doo Winter Sports Experts
Todd Arndt
Todd Arndt
ptpumpman
David Harrelson
David Harrelson
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
