SP67L6HX1X XSA Lamp not turning on - Televison & Video
X-sectional area of a power cable is 1000 sq mm-how can i understand?
This is a common way of specifying an electrical conductor. The wire is almost certainly round, and may have more than one strand.
XSA = PI * R^2 where R is radius, so a single strand of that XSA is 17.8 mm radius or 35.6 mm dia.
If the conductor has 10 strands, each is 100 sq mm and therefore 5.6 mm radius or 11.2 mm dia.
Nov 26, 2015 | Cars & Trucks
Samsung DLP TV sp67l6hx2x/xsa. New ballast and bulb. Three lights flashing. Is there a reset code for new ballast
There is lamp time reset has to be done after lamp replacement. Refer its user manual for details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 19, 2014 | Samsung Televison & Video
Hi I have a Samsung Tv. Model SP50L6HXX / XSA that wont turn on. there was a week buzzing noise for the last week or two, but tv will not start up now. The lamp light flashes on the front of tv. Can you...
I suspect the B+ voltage on the power supply can't regulate the voltage needed for the lamps to run entirely. The B+ voltage regulator looks like a small black box with a tapered top. This is dangerous to replace so be careful. Once you get a new one installed this will fix the issue you are having.
Hope this helps :)
Mar 07, 2011 | Samsung HLP5685W 56" Rear Projection...
Driver for ml-1610/xsa
www.tinyurl.com/y4hcgpc
then in downloads it would show manual and drivers
click on drivers then select the driver according to the operating system you have .
Apr 10, 2010 | Samsung ML 1610 Laser Printer
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
