Question about Sony Kp-Fx432M91 43" Projection Wega Multisystem Tv
Sony Kp-Fx432M91 43" Projection Wega Multisystem Tv price
welcomejee
  • 10594 Answers
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
Posted on May 02, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
  • 4234 Answers
SOURCE: Sony kp-46wt520 rear projection tv: standby light flashes
Two things here.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
Thanks,
Dan
Posted on Sep 18, 2009
ladywinn
  • 5138 Answers
SOURCE: Sony grand WEGA 60" with tiny blue dots all over
Sorry but you have a BAD light engine Sony is well know for this part to go bad quick, I think your tv is DLP?
Hi? My Sony Projection T.V model KP-FX432M91 is taking time to power on and once it has powered on it work fine.what might be the problem?
Power button may need to be replaced. Try turning on via remote.
Some TVs need to warm up before coming on. Hitting the power button several times may in all actuality be Turing it off and on.
Sep 20, 2016 | Sony Kp-Fx432M91 43" Projection Wega...
TV won't turn on
Here is a link with the codes for this set and others like it:
http://www.scribd.com/doc/43529880/Sony-Blinking-Codes
Personally I would suspect the high voltage block for this set is bad.
Nov 03, 2012 | Sony Kp-Fx432M91 43" Projection Wega...
Sony wega model#kp-46wt520 rear projection hdtv lamp
It uses 3 picture tubes which due to the age of the set are no longer available.
May 05, 2012 | Sony KP-46WT520 46" Rear Projection...
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
MY SONY PROJECTION TV WEGA KP-FX432 BLINKS 10 TIMES THEN TURN OFF.PLEASE HELP ME
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 22, 2010 | Sony KP-FX532M91 TV
Our t.v., which is a Sony Wega KP-57WS520, turns itself off and we can't get it to stay on. What's wrong?
If tv shut down with red led in front of tv brink 9 times,it is G board defective
p/n A -1054-157-A.Otherwise count those brinks
Jun 26, 2010 | Sony KP-57WS520 57" Rear Projection...
My sony Wega KP-57WS520 TV blinks 9 times and the picture and sound won't come on.
the blinking is an error code telling you that tv needs a new power supply.. have your tv serviced...
Nov 17, 2009 | Sony KP-57WS520 57" Rear Projection...
No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Oct 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony Wega KP 46WT520 - Flickers Green
EVERYONE CALL SONY- SONY HAS EXTENDED ALL OF OUR WARRANTIES. i have this same problem with my 60" wega. i called sony and they explained to me that the problem was the optical light box. it cost a grip to fix even for them...so instead of fixing the problem they offered me the best true flats they had at way less than the actually price. i bought a 46" bravia for less than 550 including tax. i still have my 60" but until i get it fixed on my own this 46" will definitely do. i hope this helps you all
Sep 04, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Kp-Fx432M91 43" Projection Wega Multisystem Tv Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
