Question about Astatic 600 3 Window Test Meter
I need a schematic for astatic 600 - Astatic 600 3 Window Test Meter
Where can I get it fixed?
go to Rad Shack and buy a small three way switch and put it in yourself.Is it stuck on the high end or the low? If its the high end you can still get a low reading from it. To have someone fix it may just cost as much as a new meter.So,you might think about getting a new one because you won't find another like it on the market.You can get a dosy 4002 or an astatic 600 but I'm 100% sure there are no 700's .I think workman has a twin to it but thats all I can tell you .
May 27, 2014 | Astatic "700 5,000 Watt Single Window...
Need service manual for pioneer sa-600
Head straight to the (European) electrotanya website, which offers free downloads of a wide range of service manuals. No registration is required either.
The Pioneer SA-600 schematic shows both voltages and currents. For this amp, the total current for left & right output modules (no signal) is 60mA. No-load voltage is 58 volts, dropping to 48 volts (one channel driven, 25 watts out).
PIONEER SA 600 SCH Service Manual free download schematics eeprom...
Feb 26, 2014 | Cameras
Why the swr meter do not set it goes all the way in the righthand corner this is for the astatic 600
there are knobs on the front.from the left is the set knob for SWR then next to it is the adjust knob. Turn the adjust knob to the left until the needle points to set. then take the first knob and turn it to the left.now key the mic again The needle should move to a more respectable number.
Feb 03, 2013 | Astatic 600 3 Window Test Meter
What kind of meter is needed to check modulation on cb radio
astatic 600.It has 3 windows for SWR, Power handles up 5000 watts and modulation cost about 120.00
Sep 06, 2012 | Connex 3300 240-Channels Base CB Radio
Mike wire color coat.
1 is shield (and may also need blue for astatic mic or red for turner mic)
2 is audio (white on astatic and turner mics)
3 is Transmit (Red on astatic mic or blue on turner mic)
4 is receive (Black on both astatic and turner mics)
If your mic isn't an astatic or turner, email me with what mic that you have and I'll try to help. N1PTA@msn.com
Mar 18, 2010 | Radio Communications
I need a owner manual download for Astatic 600 meter. Thanks
Try Cbtricks.com..............hope this helps you some.....
Mar 01, 2010 | Radio Communications
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Astatic 600 3 Window Test Meter Logo
Top Astatic Radio Communications Experts
AnyMHz.com
AnyMHz.com
Mike Charette
Are you an Astatic Radio Communication Expert? Answer questions, earn points and help others
