Question about Adidas LEATHER JUMP ROPE
Adidas speed rope shorten
How to adjust the length of an Adidas speed rope
escapement
  • 2334 Answers
SOURCE: How do you set an Adidas Watch (Women's ADH6051)
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please
Posted on Mar 10, 2010
escapement
  • 2334 Answers
SOURCE: I dont know how to change the date/time for my adidas watch.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please .
Posted on Mar 15, 2010
escapement
  • 2334 Answers
SOURCE: How can I remove alink from my Adidas watch strap?
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
SOURCE: Just bought an Adidas Seoul Watch ADH2044 and
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Posted on Jul 11, 2011
SOURCE: How do i set the time for my adidas ADP6002?
The watch looks and feel great; the band doesn't hurt my wrist like other watches. The instruction book, however, was awful. It was a bunch of instructions for other watches, not the ADP6002. It took a few minutes of playing around for me to figure out how to set the watch. Here's how to do it: 1) Make sure there is a little "t1" above the second hand. If there is a "t2" instead, hold the Start/Stop button for 3 seconds. (This is the part that was messing me up) 2) Hold the Set/Light button for a few seconds. The watch should say LIGHT and "OFF" or "ON" should be flashing. 3) Press the Mode button until the hour hand starts flashing. You can adjust it up and down by the Start/Stop and Lap/Reset buttons. 4) Press Mode to adjust the minute, second, and other settings. 5) Press Set/Light button when you are finished.
Posted on Nov 26, 2011
How do i set the stopwatch on the adidas adp6002
Look here for the Adidas adp 6002 manual: http://www.manualslib.com/products/Adidas-Adp6002-453238.html
Dec 08, 2014 | Adidas Watches
Where can I get /order online a replacement right side arm for my adidas A262 sunglasses Thanks Shay Atkinson
try this website
adidas spare parts: we supply all spare parts and replacement ... - [ Diese Seite übersetzen ] adidas spare parts: we supply all spare parts and replacement lenses for your adidas sportsglasses or sunglasses.
www.ad-sportbrillen.com/adidas-spare-parts
May 15, 2011 | Adidas A262 Sunglasses
Mar 14, 2010 | Adidas PEACHTREE watch
Mar 10, 2010 | Adidas Digi III Watch
How do u set the time on a adidas peachtree watch
Put "adidas watches" into your search engine and select the adidas site.
On the left of the screen is a menu , select "instruction manuals" and instructions appear.
Jan 06, 2010 | Adidas PEACHTREE watch
Adidas watch adp1059 missing instruction manual
hold set button(top left) in for two seconds until 'light 'displays,then press bottom left button(mode)to scroll though hours etc,(use right buttons to adjust)when finished press top left again
Dec 23, 2008 | Adidas Unisex wristwatch
Adidas LEATHER JUMP ROPE Logo
145 people viewed this question
Top Adidas Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Adidas Exercise and Fitnes Expert? Answer questions, earn points and help others
