Question about Mastercool 67471 Evaporative Cooler Air Conditioner
My bonaire evap cooler leaking water from ceiling air outlet
  • Champion engineering Mar 17, 2014
    take the door panels off and you will find one of the water jets is probably squirting water into the fan / housing
4 Suggested Answers
  • 47 Answers
SOURCE: I have both Heater and Evaporative cooler fitted
mate .. stop playing with it if you dont know what your doin honestly... sounds like you could end up costing yourself more money. it will b under warrenty call back the installer
Posted on Nov 11, 2009
SOURCE: Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Posted on Feb 09, 2010
  • 40 Answers
SOURCE: I have a bonaire vulcan evaperative air
check for power in the unit. check for blown fuse in the unit
Posted on Apr 04, 2011
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Bonair Evap Wont turn on after power failure
Hi bud do youself a favour before anything else take the main motor out and send it in to a reputable electrical repair co such as dynamic electrical in Benoni or look up a similar co near you and make sure that your system has not been hit bye lightning or a power surge from the supplier first I do own a Co that specialises in evap coolers and from previous knowledge a lot of the new systems have 12V inverters and if there has been a storm and you havnt diconnected your unit the PCs and motors are more than likely fried
Feb 17, 2014 | Mastercool 67471 Evaporative Cooler Air...
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Vulcan bonair evaperative cooling unit will not operaate when switched on
If shut down at end of season by air con person may be switched off in roof unit. just remove one side and should have switch in unit usually near pump
Nov 01, 2009 | Mastercool 67471 Evaporative Cooler Air...
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Problems with my bonaire evap
air con keeps shuting down takes about an hour before its cranks back up.
Nov 11, 2007 | Heating & Cooling
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
15 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
