Question about Dehumidifiers
Micromark mm9088 manual
How to remove filter
How can I purchase a replacement air filter for keystone kstad70b?
The filter in your Keystone KSTAD70B is meant to be washed. It is not listed as a replacement part in the owners manual. This is copied from the manual:
3. Clean the air filter
Remove the filter every two weeks based on normal
operating conditions.
Remove the filter from the top of the unit (See.Fig.11a),
or to remove the filter,remove Bucket then pull filter
downwards (See.Fig.11b).
Wash the filter with clean water then dry.
Re-install the filter,replace Bucket. CAUTION:
DO NOT operate the dehumidifier without a filter
because dirt and lint will clog it and reduce
performance.
If you have lost or destroyed the filter, go to Amazon and order the Duck Brand 1285234 Replacement Air Conditioner Foam Filter, 24-Inch by 15-Inch by 1/4-Inch, 1-Pack for 96 cents with free shipping as an add-on item to any order. It is also washable so you will be able to use it like the OEM filter material.
Jul 06, 2014 | Keystone Dehumidifiers
How to locate and replace internal filter?? For frigidaire
Good Afternoon Friend,
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
May 30, 2014 | Frigidaire Dehumidifiers
Shows change filter where is it located?
Hello Ann, this is JK. I understand that you are looking for the location of the filter in a dehumidifier. Generally, you will need to remove the bucket to be able to reach under to remove the filter. Please refer to your owner's manual for more detailed care and cleaning instructions. Hope this helps!
Apr 07, 2014 | Frigidaire Dehumidifiers
Dehumidifier smells stinky
Have you read its manual? http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
It says (p8):
Care and Cleaning
1. Filter
d. Re-install the filter, then replace Bucket.
2. Cabinet
a. Dust cabinet with an oil-free cloth, or using a damp cloth.
b. Vacuum grill using brush attachment.
3. Water Bucket
a. Clean bucket with warm water and detergent.
I recommend you to use a mix 75% water, 25 % vinegar. To clean its water bucket.
Oct 01, 2012 | Frigidaire FDF70S Dehumidifier
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
How do I get to the air filter in order to clean it ??
To remove the filter. remove the water bucket. Then looh at the top of the water bucket cavity. You will see a small plastic pull type handle. This is the plastic frame for the air intake filter. Pull it down to remove frame and the filter. After washing an rinsing the filter, be sire it's completely dry, before installing it. Be sure you have turned the unit OFF and unplugged it before removing the filter.
http://www.lg.com/us/appliances/dehumidifiers/LG-LHD45EL.jsp
To help you in the future, I have included a link to your Owners Manual. You can download and print it for future reference. Once the link opens look to the right on the page for Dehumidifiers Manual English and click on the link.
Jun 16, 2011 | LG LHD45EL Dehumidifier
How do I remove the cleanable filter? I cannot find the manual for my Soleus dehumidifier.
The filter is located on the right aside of the unit, behind the louvers on the front. To remove it, look for the finger hole on the side and pull the filter out. You can either vacuum the filter or wash it in tap water. If washed, be sure it's thoroughly dry, before reinserting it into the unit. CAUTION: Never remove the filter with the unit ON.
Below is a link to the Owners Manual, that you may download and print for future reference.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1305703058935/pdf/ownersmanuals/edgestar/DEP400EW_manual.pdf
Hope this helped you solve the problem. Please let me know. Thanks.
May 24, 2011 | Soleus 30-Pint Dehumidifier
How to replace or clean the filters also im trying to find a manual for this humidifier.
To remove and clean the filter: Turn the unit OFF & unplug it. Remove the water bucket and set it aside. Just under the front of the dehumidifier where you removed the bucket you will see a plastic handle. Pull down on it gently and filter will come out. Wash it with warm water and dry thoroughly, before reinstalling it in the dehumidifier. It is recommended that you clean the filter a minimum of once every 2 weeks.
As far as an Owners Manual is concerned. The following link will take you to it and you can download and print it for future reference.
http://shopping.netsuite.com/s.nl/c.618686/sc.10/category.44/.f
Hope this helped you. Please be kind enough to let me know. Thanks.
May 18, 2011 | Midea MDC-45AE Dehumidifier
What are the settings (humidity)from 40 upwards on my micromark ? . Is the lower setting to take out most moisture ? Thank You
40 is 40% humidity in room - that's really dry.
For moist area you usually want 50 or 60%.
Dehumidifiers are for damp areas. If temp ouside is below freezing, inside house is probably already too low.
Dec 01, 2009 | Dehumidifiers
Air filter
If the bucket is removed, the filter is accessible from just behind the lower edge of the grill...there should be two tabs that you can use to pull it down from behind the grill...they sometimes have clear blue tape holding the filter in, so remove the tape or pull hard and the filter should drop down for cleaning.
Oct 27, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
135 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
