Question about SimpleTech Computers & Internet
Power requirment for simpletech 640gb external hard drive
What voltage does it require?
bizelski
  • 118 Answers
SOURCE: SIMPLETECH 160GB EXTERNAL HARD DRIVE
Is this compatible with vista?
Ensure all the plugs are right and try on a different pc to see if its the pcs or the exhdd's problem
Posted on Oct 11, 2008
SOURCE: SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Posted on Nov 11, 2008
SOURCE: power supply for Maxtoe Basics External Hard Drive 500GB
Is 12VDC 2,0A the inner pin is + and the outer pin is -
Posted on Dec 04, 2008
ButtFuzz
  • 463 Answers
SOURCE: I require a driver for our Beyond micro external hard drive.
I'm pretty sure that XP should pick up your external USB hard drive with relative aplomb unless:
1. The drive is USB 2.0 and your USB ports are 1.0 or 1.1 (and even then it should work, albeit at reduced performance)
or
2. Your drive is drawing too much power from the USB hub, causing an error condition.
Try plugging it into a different USB port.
Posted on Mar 02, 2009
spiffyrodent
  • 85 Answers
SOURCE: SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Posted on Sep 10, 2009
What voltage is required for the power inlet port or is the USB cable enough?
The 2.5 inch external drive (laptop drive) does not require separate power supply because USB cable can supply enough power for this drive. The 3.5 inch external drive (desktop hard drive) requires separate power supply and it depends on the model.
Mar 01, 2014 | SimpleTech SimpleDrive 160 GB External USB...
Need AC Adapter
See the Hitachi SimpleTech FAQ's which states that "The SimpleDrive and (re)Drive lines require a 12Volts, 1.5Amp or greater, and Center Positive power adapter".
Dec 12, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
When hooking up my 120 Gb external hard drive to my laptop, I noticed there was an additional power supply required, DC by the look of it. I can't seem to find the correct size of outlet, or even an...
hi
The SimpleTech SimpleDrive Portable external hard drive features a USB 2.0 interface for speed and plug-and-play connectivity. The hard drive is USB -powered, so no extra power supply is needed.
please send me 4 thumbs up
Jul 16, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
What value of voltage is used in this 320gb hard disk?
Hi, A normal 3.5" drive requires voltage between 12 volts and 5 volts and consumes approximately 5-11watts of power.If you want to know the exact values ,check out the package of this hard-drive. Thanks, C Rahul.
Jul 04, 2011 | SimpleTech Signature Mini 320GB External...
Is it okay to use a 14-17 volt power cord for a Simpletech External Hard Drive?
The SimpleDrive requires a 12V/2A tip positive power supply. A 14-17V supply might work, but you run the risk of damaging your drive.
Mar 31, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I would like to find out the voltage and amperage of the simpletech 500gb external hard drive, I need to replace the power cord. thanks alot greg holland greg.holland@sbcglobal.net
The Pinafarina unit requires 5 volts DC at 1 ampere.
This link will take you directly to the PDF user guide for your unit in case you misplaced it.
Hope that's helpful.
Jan 01, 2011 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
I don't know which power adapter to use and I can't locate my user manual. What is the DC input? My problkem is I need to make sure I provide the right DC input - I have several adapters - what is the...
Most externals are 12v input voltage so as long as you have a adapter with this input voltage your be fine, and the hard drive should operate.
Let me know if you need more information.
Thanks
Jason
Oct 15, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Computers & Internet Logo
48 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
