Wen when turning on my garmin gps 492 i could hardly see whats on the screen could you please help me find a solution to my problem
SOURCE: Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
SOURCE: Garmin GPS screen is blurry.
two things it could be first.. you cleaned it with windex or some kind if cleaner which damaged the screen or the lcd in the unit is going out common in the older garmins... if this is the case you will have to send it back to garmin to have it repaired
haveing a hard time trying to download any updates. I dont have the disk eather for my unit. I have the streetpiolt 2720
