Question about Liebherr Refrigerators
Modbus rs485 - Liebherr Refrigerators
Can I have two different baud rate on one system
As far as I am aware, this is not possible without some additional hardware. Try looking at www.scadalink.com. They have a number of devices that may allow you to do this, especially if you are using MODBUS.
Sep 10, 2014 | GE Mds 9810 Scada 902-928 Mhz Fhss...
Does it supports any brand of cctv cameras or will there be any incompatibility with same brand..
It support all brand of CCTV.
for PTZ CCTV, It has to have the Pelco protocol so the WJ-HD716 can control the camera.
in that case, the connection will use the RS485.
Oct 19, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
Is this scanner only able to connect via USB?
HELLO,
the kit part number you have is a usb power plus kit, what you need is cable part number:
CBA-U01-S07ZAR
If you want to order one, let me know. I can be reached at 7275714159 x251
Thank you,
Kim GAnoe
Mar 18, 2010 | Symbol DS6700 (DS6707SRWU0300ZR) Barcode...
Staefa building controls
Good day,
Ensure power to NCRS board.
Ensure communications protocol on laptop is correct.
Check MS1800 is set for correct NCRS-xxx (different versions of the NCRS).
Ensure cable is RS232 or RS485.
Feb 07, 2008 | Computers & Internet
I need the rs485 codes for the ge smartcom audio hub
Need rs485 codes for Sanyo MC-600P.. Can you anybody help on this?
Jan 15, 2008 | Audio Players & Recorders
Can i transmit +12v through CAT cables?
describe your problem more correctly.
As i`ve understood i`re trying to transmit 12V via standart UTP Cable?
If it`s so - you can transmit 12V up to 40 meters length on this type of cable, if the current isn`t bigger than 2 A
Jan 07, 2008 | Cat5e 7 FT 350MHz Snagless RJ45 UTP...
Tcp slave messages are not forwarded to rtu master
I think your last sentence there might be what the situation really is.  Your not getting a reply back. Maybe you should check the response timeout the gateway has set on it for the slave.  You probably already know a slave’s response time can fluctuate wildly depending on the nature of the request sent, so maybe the timeout setting is too short? Its a place to start. .
Aug 03, 2006 | Lantronix (200.2071)
Refrigerators Logo
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
