Question about HP DeskJet 820cxi InkJet Printer
Align the print cartridges - HP DeskJet 820cxi InkJet Printer
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: print align cartridges
ALL cartridges must have ink to complete the alignment.
Posted on Jul 28, 2009
michaelshaun
  • 126 Answers
SOURCE: Aligning problems
please follow the instruction from the below mentioned url :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042820&cc=us&lc=en&dlc=en&product=79499
hope this should resolve your problem.
thanks
regards
hamid
Posted on Feb 18, 2010
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
  1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
  3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
  4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
  1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
  2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
  3. Click the Device Services tab.
  4. Click Align the Print Cartridges .
  5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
  7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
  8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Apr 19, 2011 | HP Office Equipment & Supplies
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
Feb 16, 2011 | HP OfficeJet 7410 All-In-One InkJet...
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Test page printing at the time of printer powered on
s.gif Solution minimtop.gif The product aligns the print cartridges every time that print cartridges are installed or replaced to ensure the highest-quality prints. The alignment page will continue to print every time that the product is turned on or off until the alignment process is completed. NOTE: If you remove and install the same print cartridge, the unit will NOT align the print cartridges. The unit remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. Follow the steps below, in the order presented, to correctly complete a print cartridge alignment. s.gif Step one: Remove the print cartridges minimtop.gif
  1. If the On/Resume button is not lit, press the On/Resume button to turn the product on. Figure 1: Press the On/Resume button to turn the product on c00316907.gif
  2. Make sure the paper tray is down and there is letter or A4 unused plain white paper loaded in the paper tray.
  3. Lower the access door until it stops. Figure 2: Lower the access door c00316908.gif Make sure the print carriage moves to the center. Figure 3: Print carriage in the center of the printer c00316909.gif
  4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it. Figure 4: The print carriage c00316910.gif
    • If replacing the black print cartridge, remove the print cartridge from the slot on the right.
    Figure 5: The print cartridges in the proper position c00316912.gif 1 - Tri-color print cartridge 2 - Black print cartridge
  5. Pull the print cartridge toward you out of its slot.
s.gif Step two: Install the new print cartridge minimtop.gif
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward at a slight upward angle into the empty slot. Using your index finger, push the print cartridge forward until it clicks into place. Figure 7: Insert the print cartridge c00316911.gif
  3. Close the access door.
s.gif Step three: Align the print cartridges minimtop.gif If you are installing a new print cartridge, the product begins to print a print cartridge alignment sheet. This may take a few minutes.
  1. Lift the lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass. Figure 8: Place the alignment page face down c00316913.gif
  3. Close the lid.
  4. Press the Scan button.
  5. The On/Resume light will blink during the alignment process.
  6. After the On/Resume light stops blinking, alignment is complete.
Feb 26, 2009 | HP PSC 1410 All-In-One InkJet Printer
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
I have a hpdeskjet f2180 and need to change the ink cartridges. How do I get to the cartridges to change them !
Installing print cartridges
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely when you try to remove them.
  2. Open the print cartridge door. Figure 1: Opening the print cartridge door c00906461.jpg Make sure the print carriage moves to the center. If it does not move to the center, turn the device off and then turn it back on again.
  3. Remove the tape from both cartridges. Figure 2: Removing the tape from a cartridge c00651128.gif CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 3: Copper-colored contacts c00651129.gif
  5. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Figure 4: Carriage slots c00853116.jpg Figure 5: Inserting the tri-color cartridge in the left slot c00853117.jpg
  6. Make sure you push the cartridges in firmly until they snap into place. Figure 6: Pushing the cartridge in firmly c00853118.jpg Figure 7: Tri-color cartridge and black cartridge correctly installed c00853119.jpg
  7. Close the print cartridge door. Figure 8: Closing the print cartridge door c00906462.jpg
Aligning print cartridges The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print cartridges ensures high-quality output. NOTE: If you remove and reinstall the same print cartridge, the HP All-in-One will not prompt you to align the print cartridges. The HP All-in-One remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. To align newly installed print cartridges
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. Figure 9: Loading the alignment sheet c00906464.jpg
  3. Press the Scan (c00906465.jpg ) button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Jul 29, 2008 | HP Office Equipment & Supplies
HP DeskJet 820cxi InkJet Printer Logo
13 people viewed this question
Seeker5211
Seeker5211
