Computers & Internet Logo
A
Anonymous Posted on Feb 09, 2014
Open case iomega sphdu - Computers & Internet
1 Related Answer
lacroixx1
lacroixx1
  • 101 Answers
  • Posted on Jun 15, 2010
SOURCE: need to find drivers to be able to use my portable hard drive
iomega website download the driver there or
you may try control panel /add remove hardware /
it may have retained the driver in c drive
http://go.iomega.com/en-us/?partner=4760
I forget my password, how can I fix this??
open a case with the new owner of IoMega: Lenovo:
https://lenovo-eu-en.custhelp.com/app/home
Need replacement cable for iomega sphdu hard drive
This is only an example this might not be the correct lead and you might be able to find one at your closest computer store for free local pick up.
Hope this helps.
Trying to find the operators manual for prestige desktop hard drive super speed usb 3.0 ,2 tb
The general directions is to plug the USB cable from the IOmega Prestige into any available (Open) USB port.
To open, (Access) the contents on the harddrive, double-click on the drive letter that corresponds with the IOmega.
In WinXP left-click on Start, then on My Computer.
In Win Vista and Win7 left-click on the Windows logo button, then on Computer.
You will see there are different drive letters;
Drive A: is reserved for a Floppy Drive. Older computers
Drive C: is for the Harddrive. (Hard Disk)
Drive D: is reserved for a recovery drive, or an optical drive (CD/DVD drive)
Drive E: is reserved for an optical drive, usually.
Drive letters beyond these are usually under the heading, Devices with Removable Storage
One of these drive letters should correspond with the IOmega.
Suggest, IOmega not plugged in, go to My Computer, or Computer, and look at the devices connected to the various drive letters.
Now plug the IOmega in, and see if it shows up next to a drive letter.
(Give the computer BIOS a few seconds)
Where there was NO device shown BEFORE, there should now be a device shown.
{No device shown before, but now there is. May not state IOmega, just external storage, or similar}
DOUBLE-click on the device shown.
For example:
I have drive letters C: D: E: F: G: H: I: J: and K:
Drive letter C: is for my harddrive.
Drive letter D: is for a recovery drive. (Partition in harddrive reserved for recovery)
Drive letter E: is for an optical drive (CD/DVD drive)
Drive letters F through K are reserved for an external storage device.
Whether it be an external harddrive, or flashdrive, or what have you.
IF you find the drive letter that corresponds with the IOmega DOUBLE-click right on it.
If nothing happens, or if there is no device shown when the IOmega is plugged in, there is a problem with the IOmega.
Hard to believe IOmega is still having problems with their external harddrives.
In the past they were having problems with a small circuit board located inside the IOmega's case.
[ A circuit board is a PCB.
Printed Circuit Board
For example a computer mouse has a small PCB in it,
http://en.wikipedia.org/wiki/File:Mouse_printed_circuit_board_both_sides_IMG_0959a.JPG ]
The small circuit board is an Interface Board.
It connects the harddrive inside the IOmega's plastic case, to a USB cable, and this allows the harddrive inside to be plugged into a USB port on a computer.
As mentioned inside the plastic outer case (External enclosure) of the IOmega is a harddrive.
(Hard Disk drive; proper speak)
Harddrives are measure across their Width. There are two current types used;
A laptop size harddrive, and a desktop size harddrive.
A Laptop size harddrive is 2.5 inches across in width. (2 and a half inches, or 6.4cm)
A Desktop size harddrive is 3.5 inches across in width. (Or 8.9cm)
There are two technologies used;
IDE (PATA) or SATA
I'm sure the harddrive inside susanbrenton is a SATA unit.
I BELIEVE, it is a laptop size harddrive (2.5)
Point?
If there is data (Information) on the IOmega that you must have, you may wish to buy an inexpensive external enclosure, remove the harddrive from the IOmega, and install it into the external enclosure.
The external enclosure has a plastic case (Enclosure), and a small circuit board inside. It has a USB cable, or connector, just like the IOmega does.
Once you install the IOmega harddrive inside the case, the case is closed, and it's USB cable is plugged into a computer.
(Just like the IOmega. You are just replacing the small circuit board essentially)
Once you have the IOmega's case open, and can view the internal harddrive, measure the width of the harddrive.
Buy the appropriate external enclosure.
This is one example of an external enclosure for a 2.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of a external enclosure for a 3.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Basic instructions on how to open an IOmega Prestige external enclosure (Case):
1) There are two Philips head screws on the Back of the case.
These are removed.
Once removed a the oblong panel on the end comes off.
2) You can now see the harddrive inside. Pull from the Front, and remove the harddrive out of the case.
3) The harddrive is attached with screws to a metal carrier. (Bracket, essentially)
Remove the screws, remove the harddrive.
Basic example, the harddrive will look like this,
http://www.geeks.com/details.asp?invtid=0A26923-NDW-R&cat=HDD
For additional questions please post in a Comment, (Believe upper right of your page)
Regards,
joecoolvette
3answers
How do you get the Iomega eGo Hellium 350GB hard drive to be recognized and initialized by Microsoft Vista Operating system? Have tried the instructions from Iomega and they do not work. The system...
one thing that is possible, is that you may have another drive letter assigned to the letter the iomega is trying to use.
Try this....Click on your start orb and type in Disk Management.
open the Disk Management utility in Windows and see if you see the iomega drive listed in the list of disks on the bottom.
If you DO see the iomega drive there, make sure it shows a healthy partition (It should say something like Fat 32 or NTFS as the file system type...if it shows "RAW" or "damaged" or something like that, you may need to erase and format the drive)
Then, try right clicking on the drive and choosing "Change Drive Letter and Paths..."
from there try a new drive letter in case you already have another peripheral using the drive letter the iomega drive is trying to grab. This could cause Windows to recognize the drive but still be unable to see it in your explorer.
Good Luck
I'm no longer able to retrieve data from external hardrive. Any attempt at copying and pasting from the Iomega to any of my pcs and laptops fails; only the icons themselves are pasted, no actual data. Also...
Iomega will charge you to recover thier drives, but if you open the Iomega case you will find a Seagate drive inside, Most likely a barracuda, Just go to WWW.SeaGate.com. Download Seagate DiskWizard or other free tools and follow the simple instructions to repair, Format,and or save the data on this drive..
Feel free to open the iomega case and you will find that it is a SeaGate drive, and unlike iomega
there tools r free and fully opperationel.
"I spent hours trying to figure this drive out and opend it up and found out today. but be ready to wait for the drive to be ready to use again. It is taking 4 hrs to repartition and format the drive.
I hope this works for u as it has for me.
Need to find drivers to be able to use my portable hard drive
1helpful
2answers
I have an IOMEGA 60 GB HDD probably from 2003. Power supply input is 5V / 1A. I mistakenly plugged in 16V / 4.5A from IBM PC power Adapter. Any suggestions how I can extract data or which parts to...
Just take the drive out and put it into a new enclosure would be your cheapest option to keep it portable
I label all my PSU's with a dymo label maker to try avoid the situation you just had (fingers crossed)
Or you could insert the drive into a computer that has a suitable interface eg. SATA or IDE
My Iomega 1 TB desktop usb 2.0 hard drive stopped working. it makes a ticking sound and turns off on it's own.
This means that your hard drive has died so will need to be replaced. This is what you need to do:
1. Buy a new hard drive
2. Open up the casing of your old device
3. Remove the old hard drive
4. Place the new hard drive in the bay
5. Re-assemble the casing and plug in
2helpful
Iomega HDD 160 GB
Hi
If it is connected to the mains ,make sure it's correctly connected.
Also try another USB port on the computer.
If it used to switch on before or even make sounds to show that it was working and now it doesnt then it's either a problem with the harddrive case or the drive itself.
To retrieve the information on it(if the problem is infact the case) then you will need to open the case and remove the harddrive from it and then buy an external USB case for it ,or if you are technically good with computers attach it internally to the computer.
Good Luck
Please rate answer if it helped ,if not then let us know.
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
Grand Canyon Tech
Grand Canyon Tech
