System initializing xerox
Xerox work center 3210 error. system initialize show on the screen
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
  • 526 Answers
SOURCE: XEROX Phaser 8560MFP won't go past "initializing?"
Disconnect the data cable between the Electronics Module and the Printhead to see if Power On Self Test (POST) gets further, to the point where it displays a system failure code relating to the Printhead being disconnected. If so, replace defective printhead.
Posted on Dec 13, 2009
  • 10406 Answers
SOURCE: xerox 3210 workcentre -
System error --> software inside the printer has detected some sort of "software" error.
Cycle power -> disconnect the AC power.
Wait a few seconds.
Reconnect the AC power.
Turn the printer on.
Posted on Jan 22, 2010
HOW DO I REMOVE PASS WORD ON 3210-3220 XEROX WORK CENTRE IN FAX SET-UP?
You can contact a Xerox service center and see if they can provide the default password. In most of the WorkCenter MFP's the previous owner would seldom change the default. But if they did, the Xerox service tech can probably tell you how to reset it once you provide the serial number and proof of ownership.
Dec 24, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
HOW TO RETRIEVE ITEMS IN MEMORY IN XEROX 3210/3220 WORKCENTRE FAX ?
dear Is there any error or masage disply on the screen. Pl. revert back.
Thanks.
Dec 18, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
I need printer driver for my old xerox phaser 3210 for windows 7
You can find one here:
http://www.driverfiles.net/Printers/Xerox/Xerox-Phaser-3210-PCL-6/download/page,sh,17467,130,12,.html
If the link doesn't work, just go to driverfiles.net and look up your printer by make and model. You can find most of your drivers here fyi.
Aug 03, 2011 | Office Equipment & Supplies
My 3210 shows Ink System Failure error what does that mean and how do I fix it?
hi there
we have one printer like that in our company and the problem is the same ink failure system i tried to check and clean the ink line but the problem is still the same, i try to bring it in hp service center and it is fixed but it willcharged you little bit high. try to unplug all the power from theprinter and also in the wall outklet and wait for sometime and plug it again. if the problem is still the same my advised is consult hp service center.
thanks
Apr 23, 2011 | HP Photosmart 3210 Printer
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
For Xerox 3210 printer, after replacing the Print Cartridge, it is showing "Toner exhausted'. What is the solution?
Here's what my Service Manual for the WorkCentre 3210 States:
  • Replace the Print Cartridge
  • Cycle system power
  • If problem persists, refer to the following procedure.
  1. Check the Toner Remaining Count. Is the cartridge at or near end of life?
  2. If yes, replace the cartridge
  3. If no, Reseat the print cartridge and cycle the system power. Does the problem persist?
  4. if yes, Reseat CN20 on the Main Controller Board and cycle system power.Does the error persist?
  5. If yes, check for +3.3V @ CN20-4.
  6. Is there 3.3V @ CN20-4?
  7. If yes, replace Print Cartridge
  8. If no, Replace the Main Controller Board.
If you've already replaced the cartridge and rebooted the printer and it still gives the error and your machine is still under warranty or a service contract. Contact your Xerox Service Provider and let them do all the stuff I mentioned above. That's what you're paying them the monthly maintenance agreement for!
May 17, 2010 | Office Equipment & Supplies
Xerox 3210 workcentre - ''system error cycle power'' what does it mean/
Wait a few seconds.
Jan 22, 2010 | Office Equipment & Supplies
172 people viewed this question
k24674
