Question about Saniflo & Saniplus& Macerator Pump
When I flush the toilet the macerator comes on for about 10 seconds is this clearing correctly
  • 33 Answers
SOURCE: The macerator wont turn off after toilet flushed -
try cleaning with an acid descaler. if that doesnt work then its time to replace the pressure switch (micro-switch). These often give up well before the unit has reached its last legs.
Posted on May 10, 2010
  • 115 Answers
SOURCE: How to unclog the macerator - Saniflo TurboFlush P
First unplug the unit from the GFI, remove all the piping attached to the pump, remove the pump completely out the back of the toilet. Pry open the lid with a flat head screw driver, remove 2 screws in front of the pump and the motor and pressure chamber can be pulled out the top as one piece. Inspect the blades (on top of motor) also inspect the impeller which is at the bottom of the motor, you must turn the black pump cover plate counter clock wise to unlock it and inside there you will find the impeller. Also check the drain pipe for obstructions.
Posted on Jul 27, 2010
  • 115 Answers
SOURCE: How do I know if the macerator is working if I
If you flush the toilet at least 3 times and water does not back up on the toilet then is working. In case the pump fails the pump will fill up about 3 to 4 gallons of water before it overflows or backs up. You can also try disconnecting the discharge pipe off the discharge elbow and place a bucket at the end of the discharge elbow and flush the toilet into the bucket, if water is discharged into the bucket then is working properly.
Posted on Aug 11, 2010
  • 115 Answers
SOURCE: After flushing the macerator kicks
Typically this will have if the pump is either not vented at all or lack of air flow on the vent pipe. Most of this units have an 1 1/2" vent connection on top of the lid which should be vented to the open air to allow air to flow in and out of the vent pipe at all times. If you already have a vent pipe connected, disconnect it from the top of the lid and leave the vent connection open to the room so air can flow in and out, then flush the toilet, one flush should get rid of all the solids. Also check the rim of the bowl, water should enter evenly all around the rim of the bowl. If you see more water on one side than the other, then could be calcium build up or an obstruction inside the rim of the bowl.
Posted on Oct 11, 2010
SOURCE: I have a toilet with
This seems like a problem with your cistern and not your macerator - I have a similar set up and if your push button is stuck you need to check the mechanism in the cistern - also you should have an overflow that drains into your loo within the cistern so you should check this for blockages as well.
Posted on Oct 20, 2010
When we flush machine runs and waste goes properly but waterlevel goes high . during flush time the toiletbowl filled with water
Sounds like your external pipe may have a blockage tap the pipe to see if your hear a thud if it sounds clear check the toilet outflow pipe the same.. You may need to have your external pipes rodded.
Jan 08, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
I have just installed today and when flushing toilet the water is pumped away but the motor just keeps running and overheated then cut out
Gain access to the macerator float(s), and make sure that they operate freely. You may have some packaging or other material preventing it's correct operation.
--W/D--
Jan 19, 2011 | Saniflo & Saniplus& Macerator Pump
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
I have a toilet with a push button flush mechanism (allowing half or full flush). The toilet has a macerator behind it. If you flush the toilet and the macerator jams, the push button stays stuck in and...
Oct 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
How do I know if the macerator is working if I flush the toilet I acn hear the pump start and see the 22mm outlet pipe vibrating as water is pumped thru it. But I'm not sure if macerator is working. Does...
Jul 20, 2010 | Saniflo & Saniplus& Macerator Pump
At the moment we have a saniflo plus but the whole system has blocked but the pipes are clear what should we do next
If the toilet doesn't flush but the rest of the plumbing works fine you may need to buy a closet auger to clear the toilet stoppage, they cost around $20 and do wonders much better then plungers
Jun 25, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Bad smell fro macerator when toilet flushed after being left overnight
Typically on macerating or grinder pumps there is a small 1/2" breather hole on top of the lid, about the size of a dime or nickel. That breather hole must be kept plugged or seal cap. If left open, odor will escape through there. Make sure the pump is vented using an 1 1/2" vent pipe which must be vented to the open air so air can flow in and out of the vent pipe at all times. Also you might want to check for loose connection or waste water leaking from the pump, toilet or any of the connections.
May 21, 2010 | Saniflo & Saniplus& Macerator Pump
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo & Saniplus& Macerator Pump  Logo
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
