Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi My power supply has come up missing. I cannot find my manual so I don't know the number of the power supply in order to replace it. Can you help?
  • pj5255 Oct 26, 2007
    I do not have the cable that plugs into the wall.
  • Anonymous Nov 14, 2007
    I have the same problem. The power supply cord and conveter are missing. This monitor does not use the standard three prong plug power cable that is the standard of most computers.
  • 328 Answers
Power supply for what exactly? The monitor plugs the wall outlet. Do you mean cable?
Posted on Oct 26, 2007
  • Lyle Siemens
    Lyle Siemens Oct 26, 2007
    Thats easy, any electronic store that sells computers will have a cable. Just tell them what you need it for.
Tv LCD RCA model L32WD22 what ic replacement can I use?
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Mar 17, 2010 | RCA L32WD22 32 in. LCD HDTV
How can I download the info for my KOGI - L7CH - TA-AV53N-2000-KGX monitor. I did not receive a disk at purchase from Best Buy (they lose everything that is a display item!). I was able to use it...
Simply go on the Kogi website. be sure you know your purchase serial number and model numbers for prompt service.You should be able to access manuals and drivers ect....
Jan 27, 2009 | Kogi L7CH Monitor
My Kogi 17 inch monitor illuminates for 2 seconds and then the light goes out. The monitor is still on but hard to see. Each time you power cycle the monitor, the display appears normal for exactly 2...
Hi and welcome to FixYa,
Initially, lets try determining which is at fault.
  • power supply (unlikely) - the unit powers up, even after the display going off, the monitor is till on;
  • LCD screen (possibly) - will have to be determined later;
  • CCF Lamps (backlights) and/or inverter (most likely) - a check; power on the unit, run through the routine, change channels etc. with a flashlight shine obliquely against the screen. If with the use of the flashlight a darker semblance of the desktop could be seen, then you have just confirmed that it is either the CCFL or the inverter and definitely not the LCD screen.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Is there a question somewhere in that statement? So what it takes a power supply, so does mine. Are you missing one, and need to know which one to get? You can buy replacement and generic power supplies off of ebay. The output should be 12VDC. Not sure how many amps you need from the power supply, but a 4 or 5amps should do fine.
Now you just need to make sure the plug is the correct size and voltage orientation. This sounds complicated but it is not. 99% of the time the tip of the plug is +12VDC, and the other part is ground. Some ebay auctions will even list which monitors there particular power supply will work with.
Nov 14, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi L4AX 14" LCD Monitor.
my supply has the following specs.
AC input- 110-240v 1A  47-63Hz
DC output 10-17v  3.5A
Nom. V 12v
Nom current 2.9A
output power 35A max.
With this you can likely find a universal "brick" that covers your needs
Oct 14, 2007 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
100 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
