Question about Emerson LC391EM3 39 in. LCD HDTV
Tv channel stuck on 117.1 - Emerson LC391EM3 39 in. LCD HDTV
Comcast remote code for toshiba 34hf85 tv
Hello
Set up codes for Comcast universal remote to Toshiba TV are:
0154, 0156, 00600159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
You can also try these numbers too.
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Mar 06, 2012 | Toshiba 34HF85 34" TV
My Innovage Jumbo remote will not control the tv volume
If you have only partial control of your device, I recommend trying another code for that brand. For Toshiba TV's the codes are: 013, 049, 089, 105, 109, 117, 118, 120, 159, & 178.
Jul 12, 2009 | Innovage Jumbo Remote Control
Audiovox 9'' drop down tv with poor sound
You need to go to cable instead of air and search for channel
Feb 07, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
TV (RCA model F32705) stuck on one channel
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Jan 04, 2008 | RCA P46924 46" Rear Projection Television
Unable to channel to channel 3
If you take a working remote, point it at the TV and hit "3", then "ENTER", does the set go to channel 3?
Sep 04, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Emerson LC391EM3 39 in. LCD HDTV Logo
11 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
