Question about Casio fx-300ES Calculator
Quadratic equation - Casio fx-300ES Calculator
5 Suggested Answers
  • 7993 Answers
SOURCE: how do i enter the equation 5x-3=11+12x
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 (not your expression)
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter.
Posted on Aug 21, 2010
  • 7993 Answers
SOURCE: How can I compute quadratic
You cannot solve the quadratic equation with this calculator. It does not have a solve program.
However if you wnat to create a table of values for a function (any type of function that uses the basic scientific function keys ) you use the TABLE Computational Mode.
You press MODE
You select TABLE
You enter a mathematical expression 3X^2-.33X+ 15
You generate the table of values.
Posted on Sep 03, 2011
SOURCE: how we get quadratic equation
Hi rayalak857,
Have a nice day.
Calculator does not have a solve program, but you can use it to solve the quadratic equation with a little effort. If you know the theory skip toward the end.
Here is the example:
Let aX^2+bX+C=0
1. First calculate the discriminant usually called Delta and given by
Delta =b^2 -4*a*c store the value in the variable D
If Delta is positive you have two roots X1 and X2 given by
X1=(-b+square root of Delta)/(2*a)
X2=(-b- square root of Delta)/(2*a)
If Delta is equal to 0, X1=X2=-b/(2*a)
If Delta i negative, no real solutions exist
You only solve if Delta is positive or equal to 0.
Putting in the values of a, b, and c
value of a (put you number) [SHIFT][STO] A
value of b (put your value) [SHIFT][STO] B
value of c (put you value) [SHIF][STO] C
[ALPHA] B [X^2] -4[x][ALPHA] A [x][ALPHA] C [=]
Value of delta is displayed. If it is positive, you store its square root in D
[Square root] [ANS] [SHIFT][STO] D ;
Calculate 1/(2*a) and store in variable F
1./(2[x] ALPHA A) [SHIFT][STO] F
To obtain X1
[ALPHA] F [x] ( (-) ALPHA B + ALPHA D ) [=]
To obtain X2
[ALPHA] F [x] ( (-) ALPHA B - ALPHA D ) [=]
Be careful: the (-) is the change sign not the regular minus sign.
Hope it helps. Goodluck
Thank you for using fixya.
Posted on Sep 13, 2011
  • 102366 Answers
SOURCE: How to solve quadratic equations on fx82ms calculator
You can do it the same way people did it before calculators were invented. Just use the quadratic formula: http://en.wikipedia.org/wiki/Quadratic_formula. Some sophisticated calculators have generalized equation solvers that can handle equations much more complicated than the quadratic, but the fx-82 isn't one of them.
Posted on Nov 06, 2013
Factor quadratic equations
The calculator cannot do symbolic algebra. If equation is aX^2+bX+c=0, write it in the form a(X^2+(b/a)X+(c/a))=0 and solve the quadratic equation X^2+(b/a)X+(c/a)=0. Get the approximate roots X1, and X2 (if they exist) and write your original equation in the for
a(X-X1)(X-X2)=0
Your quadratic polynomial is factored as a(X-X1)(X-X2)
May 28, 2014 | Casio Office Equipment & Supplies
Nov 06, 2013 | Casio FX82MS Scientific Calculator
Quadratic equation fx-82ms
You can do it the same way people did it before calculators were invented. Just use the quadratic formula: http://en.wikipedia.org/wiki/Quadratic_formula, and let the calculator handle the arithmetic. Some sophisticated calculators have generalized equation solvers that can handle equations much more complicated than the quadratic, but the fx-82 isn't one of them.
How can i solve quadratic equation (aX^2+bX+c=0) with my BA II plus texas instrument calculator?
The BAIIPlus doesn't have anything specifically for solving quadratic equations. You can simply plug the coefficients a, b, and c into the quadratic formula.
Oct 03, 2013 | Texas Instruments Office Equipment &...
How to solve quadratic equation in fx-100ms
See if it has an equation mode, and select quadratic equations. If it has a SOLVE feature, enter equation, provide a guess and solve.
Feb 26, 2013 | Casio Office Equipment & Supplies
I want to solve an complex equation on casio fx-570 ES Plus
Your scientific calculator is unable to solve complex equation with complex coefficients. You should try to solve by hand directly using the quadratic formula or by factoring the polynomial in z
failing that, another way would be to set z=x+iy, substitute this for z, carry out the algebra and try to separate real and imaginary parts. But your two equations will constitute a system of two quadratic equations. I am not aware of any general method to solve coupled nonlinear equations.
Good luck.
Dec 20, 2012 | Casio FX-115ES Scientific Calculator
How do you do quadratic equation
If your equation is ax^2 + bx + c = 0 then the quadratic equation is 3ea647783b5121989cd87ca3bb558916.png. Just plug the corresponding numbers into the formula and you will get the answers.
May 11, 2011 | Sharp ELW535 Calculator
Can you factor quadratic equations on the Casio fx-11ES? If yes how?
Press MODE 5 to bring up the equation types. Press 3 for the quadratic. Enter the three coefficients. Press = to see the first root. If the display shows x1 then press down to see the other other root. If the display only shows x then that's a double root. Given the two roots x1 and x2, the factors of the quadratic are (x-x1) and (x-x2).
Refer to "Equation Calculations" on page E-55 of the manual and examples #094 and #095 in the appendix for examples of solving quadratic equations. If the you need the manual and/or appendix, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
May 11, 2011 | Casio FX-115ES Scientific Calculator
How to solve a quadratic equation
The form of quadratic equation is
The roots of the above quadratic equation are
Nov 07, 2010 | Computers & Internet
Want to solve quadratic equations on my casio 3650p super fx
In your manual, Appendix Program Library, (Page A1) you have the listing of the problem to solve the quadratic equation. Type it in your calculator and execute it.
Hope it helps.
Aug 13, 2009 | Casio FX-9750GPlus Calculator
Casio fx-300ES Calculator Logo
15 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
