Question about Asrock Computers & Internet
Flashing display board
My board is not giving display
Jandy display flashes on and off
if it is flashing error code 1 while flashing you have a shorted temp sensor if no flashing 1 sounds like display board you can disconnect temp sensor 2 black wires that go into power control board disconnect with unit off then turn back on if no flashing it was the temp sensor
May 24, 2013 | Jandy Laars Lite2 Pool & Spa Heater -...
Tip
Intel 845gvsr mainboard no display problem
this problem is normal because of the BIOS chip failure normally
symptoms:
when u get ram out and start computer it gives beeps and when u put back the ram and power on PC it gives no beep no display.
Fix the problem:
tools required:
1. hot air gun
2. 512kb fresh bios chip/ if the old chip is right then no need of newer one
3. p3 mainboard (with the BIOS socket) for reprogramming the chip
4. dos bootable hard disk
5. bios bin file.
have not the file ,
don't worry: this file can be made from the bios chip of a working mainboard using the bios flash utility.
flashing software: best is Uniflash.
Procedure:
1. with hot gun, get the bios chip out of the board,
2. reprogramme the chio with correct bin file.
3. put the bios back
Reprogramming:
copy the file in dos bootable hd
run the hdd on p-3 board
pull the bios out of running board (with slight care)
put the 845gvsr bios chip in place of p-3 bios
run uniflash and flash the bios
power of p-3 computer and get bios out
for how toprogramme bios chip : check the page
http://www.pcnineoneone.com/howto/biosflash1.html
on Jan 24, 2010 | Computers & Internet
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a Canon MX300 which has been bought 2nd-hand. There are new Canon original inks installed. When I switch on there is brief activity then power and error lights flash alternately. The display panel...
Is verry bad,the printer have logic board defect....you need to replace the logic board.I look in the service manual and 9000 error means to replace the logic board.If i have been useful please give me a vote :).Thanks
Apr 04, 2011 | Canon MX300 Office All-In-One Printer
TV wont power on. Upon starting green light on front of display switches to flashing red. I have already unplugged power and tried again
This should be an error code 14. Most of the Philips TVs with this code means the Audio is the problem.
The Audio board maybe shorted out causing the TV to go into "Protection Mode". I would try unplugging the Audio board from the main power supply board and main mother board to see if the TV powers up without going into Protection Mode. That should give an answer if the Audio board is bad or not.
Apr 01, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
7000 PT will not start up (display flashes)
On that relay board their should be 2 lights engaged:
1.power 2.relay.
It sound like a loose connections there are 3 connections to the board first that I would look is the power connections to see if their is no broken wires, than the connector that goes to the display that may have exposed wires that may be grounding out on the frame and by jostling the connectors and see if either one stops the light flickering and relay clicking.Their can be also cold soldier connection on the relay board. Hope this helps
Feb 11, 2010 | Stairmaster Stepmill 7000 Pt
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
Display Flashes
I wouldno't say the LCD needs to be replace. If the repair shop said that the inverter board is the problem, it could be but the way the LCD is behaving; i would suspect the power supply might not be providing the proper voltage to the inverter board circuitry making the LCD flash after it warms up.
Let me know if you need further assistance.
Jun 17, 2008 | Toshiba 32HLC56 32 in. HD-Ready LCD...
LCD display
This 1.7" LCD is made by AUO and it is most likely defective. You may try reseating the internal ribon cable of the LCD connected to the printed circuit board by opening the camera back case (5 small screws) with a tri-wing screwdriver size #000. Care must be taken as the flash light charging circuit is active and touching certain area of the board may give a big shock once you have access to the internal guts of the camera.
Jan 18, 2008 | Fuji FinePix A350 Digital Camera
Display failure
Hi, This is the problem with display contact with the coard.. there will be some dry solder happened on the board. give it for a normal service and ask them to check for this loose contact.. all the best regards sreejith
Jul 09, 2007 | Nokia 6230
Computers & Internet Logo
11 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
