Question about Yamaha DSP-A1 Receiver
I own yamaha htr 2064, all of sudden it stopped playing the sound from all the inputs (Tata sky / BD Player / TV) when tried after 3 days it stated playing normally and once again sound cut off. When taken to service center they said DSP Board is faulty and need to be replaced. Is it the only option? If so how much will the board cost me?
SOURCE: volume level dropping unexpectadly
The A1 has an internal self diagnostic program which you can go through to find the fault. You can access the diagnostic program by simultaneously pushing some buttons on the front panel. The Yamaha service manual for the A1 tells how to do it and what the diagnostic codes mean. You can get a copy of the service manual on the web from several suppliers for a small fee.
Posted on Jan 20, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Posted on Apr 11, 2009
satavlad
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
  • 4234 Answers
SOURCE: I took my receiver to the local Yamaha repair
The board price won't be cheap. Were they going to replace the board or repair it? It is possible that the component parts are not available from Yamaha and the only option is to replace the board. Other shops may be able to repair the board. What was the original problem that lead them to want to replace the board?
Dan
Posted on Mar 26, 2010
How can I lock my Input Mode setting?
sounds like you have too much hooked up trying to do the same thing and are fighting each other .
May 12, 2015 | Yamaha Audio Players & Recorders
Yamaha HTR-5990 Audio no longer works
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Jun 21, 2007 | Yamaha HTR-5990 Receiver
We cannot get sound through the yamaha amplifier while watching a dvd? TV and Foxtel works but we only get sound from the tv when we are watching a dvd. we have a Sony Bravia TV and a Yamaha HTR6130...
You need to connect the unnamed DVD player's audio to the receiver according to the player's manual and then assign the digital input on the HTR (if applicable). THAT would be in the HTR's manual (page 6).
I'd run the DVD's best video straight to the TV. Nothing good comes from having unnecessary cabling or interconnects zig-zagging across the room.
Jun 26, 2011 | Yamaha Audio Players & Recorders
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
Nov 28, 2009 | Yamaha RX-V463 Receiver
Hooking up multiple components to HTR 6030
Once you have installed all the cables to the system, you will need to go in to the Yamaha's system settings (see owner's manual) and assign the audio inputs accordingly. The DVD input will need to be set to the optical input # you have selected. Optical and digital coax are not preset in most cases. Once you get to the input selection assign the digital # for DVD and then exit out. You should begin to hear the audio immediately. If not you missed a step. I do this for a living and every unit has its own routine you need to learn.  Enjoy the system Rob
Feb 27, 2009 | Yamaha HTR-6130 Receiver
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha DSP-A1 Receiver Logo
76 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
