Question about Dyson Washing Machines
Coin trap blocked at rear near pump - Dyson Washing Machines
4 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Frigidaire Front Load Washer (E20)
remove the bottom panel ,,the pump is in the front left hand corner...unplug frist,,,you will see to black 2 in hose ,,1 is the drain hose check all the way up the line,,,the other is the tub to pump hose it has a sump on bottom ..remove everything out but dont stick your finger in it,,turn it upside down,,in case of small sharp metal object. onthejob
Posted on Jan 28, 2009
  • 6 Answers
SOURCE: Clothing and coins continually become trapped
Try to put a small amount of clothes,more waters.
Posted on Jan 09, 2010
  • 5 Answers
SOURCE: my machine unable to complete program its saying
To find your coin trap:Loot at the front of the machine, and at the bottom-left is the coin trap.Put towels in front of the machine to mop up any water (it's going to get wet).It opens anti-clockwise (remember righty-tightie, leftie-loosey), but you need to move the little bit of yellow plastic (12-oclock position) up first. The machine dose come with a little tool to do this, but you may have lost it. You can move the bit of plastic up by carefully using a flat screwdriver, and turning the round plastic with your other hand. Don't force anything. After you remove it, just swim over to your machine and remove the yellow thing in the middle by pulling it gently towards you. Clean out the coins/paperclips/buttons that you find in there.Push back on the yellow bit into the coin tray, tighten back on the cover the coin tray (the yellow thing at the top will 'click' back).Using a mop, take the opportunity to clean the kitchen floor now that it is all wet.
Posted on Dec 24, 2011
What is coud e00
Check the pump trapped there may be coin lint block pump from draining there a panel on the washer front right down near the bottom of washer were the pump located at
Mar 03, 2015 | Bosch Washing Machines
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
Washing machine not draining
see this causes and fix it. God bless you
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Washing Machines
Kenmore 417.43042200 Front load washer. Replace shock absorbers and coin trap
Hello Karen,
The following video should fully explain everything that you should know on how to do this replacement and any warnings.
Good Luck!
Rich Lilja
Apr 27, 2017 | Kenmore HE2 Plus Front Load Washer
GLTF2940E not spin rinse drain problems
I would check the drain pump for objects. There is a trap that will collect coins and stuff. As this trap builds up it restricts/blocks the water from being drained from the washer.
Aug 07, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front loading washer, kenmore 417.42052100 won't completely drain and leaves a tub full of water. Has been getting worse over the last week and now won't drain at all. Took off front panel to try...
The drain filter/coin trap is blocked or the pump is no longer working. The filter/trap is located inside the big black hose that runs from the bottom of the tub to the pump and hence the name tub-to-pump hose. Clean the filter and inspect the pump impeller for damage or restriction.
Disconnect power then remove the screws attaching the bottom front panel to the cabinet then pull the panel down and off. Once the panel is off, you can now loosen the clamps securing the tub-to-pump hose to the bottom of the tub and the pump's inlet then take the hose out and clean the filter/trap.
You should find foreign objects such as coins, toothpicks, hairpins and the likes blocking the filter. Clear the filter from the foreign objects and inspect the pump impeller by turning it with your finger. The impeller may be restricted or damaged resulting in the water not being pumped out properly or none at all. Replace the pump if the impeller is broken or restricted and doesn't turn freely or if the pump is no longer operational. You can tell the pump is no longer operational if all are clean and the impeller is in good shape and turning freely. Reassemble the machine by following the steps above in reverse order.
When installing the filter in the coin trap, the top ring of the filter MUST be seated in the 3rd convolution from the bottom.
Jun 20, 2011 | Washing Machines
My washing machine spins at end of its cycle, however, the clothes are still soaking wet. Will it be that the pump has gone as I've emptied the filter
most likely the pump is blocked......................small coins easily block em......
did 1 last monday and the pump had a penny pluss a wire from a womans bra..........
just clear the pump and job done.......
see if you can get machine near an open door first .....
let rear hose lay outside,...
it will help get some of the water away............
cheers
Apr 13, 2011 | Washing Machines
Machine won't spin
The most common reason for this is the pump is jammed - usually with a coin or sock or something.
The pump may be accessible from the front bottom of the machine - look for a little box open it - and you will access the coin - you can clear it and try again - remember to put the coin trap back together again.
Alternatively, if no coin trap is present you will have to tip the machine back - and look for the pump usually it has two black hoses going into it and it is situated near the bottom of the machine - remember when removing the pipes water will come out - so - have a bucket close by to catch the water.
you may find what is jamming the pump there - if there is nothing the next likely culprit is the timer... try moving the programme dial on a little bit see if the spin starts - if you have a digital machine there will be no way to try the last fix.
But the pump is almost always the problem!
Good luck
Jan 07, 2011 | Washing Machines
Error code e20
error code means that the coin trap/drain pump hose underneath the machine needs cleaned out due to being blocked.
Jan 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
The pin trap will not screw back into the washer
Check you have not pushed anything into the pump, also clear any limescsle away
Feb 02, 2018 | Asko W6021 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
