Question about LG RH397H DVD Recorder
Lg rh397 powers up but won't turn on - LG RH397H DVD Recorder
Washer won't turn on
you have to check there power supply cable...and power on button..step down transformer on the pcb....7805 and 7812 power regulater ic
May 22, 2013 | LG WM2140CW Washer
Lg 37" won't turn on
thats usually a power supply issue. If so you can get the power supply from www.tvrepairworld.com
Mar 29, 2013 | LG 37LC7D 37 in. LCD HDTV
Hi my LG 47 LH4000 turned off and won't turn back
More than likely your power board is defective
Mar 20, 2013 | Televison & Video
Wash machine LG wt5001cw won't turn on
I have a LG wt5001cw top loader washer and after it completed its cycle it shut off and will not turn back on. How do I fix it?
Jan 12, 2013 | LG WT5001CW Washer
LG 42LK45OU won't turn on
Do you get the power/standby light to come on?
Mar 17, 2012 | LG Televison & Video
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Aug 07, 2011 | LG WM3987HW Front Load Washer / Dryer
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
LG RH397H DVD Recorder Logo
46 people viewed this question
Computer Repairing
Computer Repairing
