Question about uk.com
How to remove monthly z reports using eltrade
My Eltrade Etr machine is not turning on. Please help
This item does not appear to be connected to photography in any way.
Sep 07, 2017 | Photography
How can I get a monthly report from casio cash register se_s700
DOING A MONTH-END REPORT
1. Turn mode switch to Z mode
2. Enter 10
3. Press Cash Amount
4. This Z Monthly reports clears all totals for the month.
Nov 17, 2016 | Retail Supplies
How to get back dated monthly z report on casioqt 2000b . please any one thanks
Press X/Z button Periodic 1Z Batch Batch 1
make sure you have been resetting it each month or you will have a huge total in there that will be meaningless. If this is the first monthly you have ever done, ignore the first report, then the next report will be correct next month
If anyone needs more information, the Casio QT-2000 manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jun 01, 2011 | Casio Parts Cash Register PC Desktop
Is it possible to print report from last month?
Not likely, fax machines only hold the last 50 transactions.
Sep 27, 2009 | Canon L220 Plain Paper Laser Fax
Monthly copy count
If is not selected to mountly report ,you don`t can obtain the report.Exist one aproxim. solution:make a calculation if you change the toner amd the numbers of copy in this day and obtain the result aproximat.
Sep 02, 2009 | Canon imageRUNNER C2620 Color Copier
How do i get a confirmation of a fax sent over a month ago?
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to
print automatically also.
1. Press Report/Help.
2. Choose the report you want by using !".
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed. The available reports are shown below:
Report name Content
Multi-Communication This report prints automatically if you have faxed documents to
more than one location by using Broadcasting.
Power Fail Report If you have a scheduled job (such as, delayed fax and send poll)
and there is a power failure, this report is printed automatically
when power is restored.
Report name Content
Help List This report covers the machine’s basic functions and commands.
It can also be used as a quick reference guide.
Sent Journal
Received Journal
These reports show information concerning the transmission and
reception activities. They can be printed on command. Or if the
machine is set to do so, they will automatically print after every
40 transmissions or receptions. For more information, see Fax
Log under the “BASIC FAX menu” on page 13
Phonebook This report shows all of the numbers currently stored in the fax
machine’s memory as One-Touch Dial and Speed Dial.
Sending Confirm This report shows the fax number, the number of pages, elapsed
time of the operation, the communication mode, and the
communication results. To set up your machine to automatically
print, see Sending Confirm under the “BASIC FAX menu” on
page 13
Aug 25, 2009 | HP 1040 Plain Paper Inkjet Fax
Casio TE-2000 Till - reprint Z Reads
when i type no. 9 there are additional numbers added
Apr 24, 2009 | Casio Parts Cash Register PC Desktop
Casio 101cr.i need a users manual.
Hi. These registers are about the most basic you can get, so they can't do a daily and monthly total.
Basically it works like this:
The machine doesn't care when you do your reports. It will just total up until it gets reset by someone. If you want a monthly, just do your reports each month. However, this means you can't do a daily.
If you turn to X mode and press CASH, you get the total so far (since you last did a Z report).
If you do the same in Z mode, it will give the report, then reset the report to zero.
If you want to see daily and monthly, you can do an X at the end of each day which will show that day and the previous days together. you will need to subtract the other days to find out what todays takings are. Then at the end of month, do a Z and that will reset you for the next month.
Otherwise, if you are interested in monthly only, then just do a Z at the end of each month.
So, what I'm saying is the machine doesn't care how many times you do an X report. It will just show you how you are doing so far, but you must do a Z report when you want it to reset everything. If you want to check if the Z report worked, just wait for the report to print, then press CASH again straight after, and you should see the figures have gone.
I hope this makes sense. If you need more advice, just ask.
Mark
Oct 08, 2008 | Casio Parts Cash Register PC Desktop
SPREADSHEETS
Excel is not able to be programed like that and still retain the data. Create 12 monthly spreadsheets and use them as they are needed.
Dec 08, 2007 | Computers & Internet
uk.com Logo
Top uk.com Computers & Internet Experts
David Payne
David Payne
Are you an uk.com Computer and Internet Expert? Answer questions, earn points and help others
