Question about Canon imageCLASS MF8170C All-In-One Laser Printer
Canon imageCLASS MF8170C CON ERROR 021 ERROR DE SITEMA. QUISIERA SABER QUE SIGNIFICA ESE ERROR Y COMO LO RESUELVO?
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
  • 40 Answers
SOURCE: error canon 3220 E000004-0004
try cleaning the photointerrupter at the behind of left top delivery ***'y
Posted on Mar 08, 2010
antoniecoinn
SOURCE: MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
Posted on Mar 02, 2012
Mi carro es un nissa sentra del nobentaicutro De cuatro indectares y uno no functions Como lo ecsamino para saber si es el prolema
cambialos de posicion! AUNQUE LOS inyectores RARAMENTE FALLAN, pudieras tener mas problema de falla con IGNICION!, asegurate que hay chispa en ese cilindro, y ya es hora de cambiar cables y bujias tambien... TIENE FILTRO DE GAS NUEVO?
Aug 06, 2014 | Cars & Trucks
Code p1682 driver 5 line 2
Mi chevy equinox 2007 esta con un grave problema en el encendido, cuando arranca, lo hace deficientemente y la pantalla dice que hay perdida de potencia, conecte un OBD II y me da el codigo P1682 driver 5 line 2...quisiera saber que significa y como puedo resolverlo,ya que es muy desagradable lo que estoy pasando
Apr 11, 2014 | 2007 Chevrolet Equinox LS New Cars
Mi impresora canon mp280 me sale el error b200 que puedo hacer..la tinta ya no corre
pruebalo con uno de los cartuchos afuera. si es que ves que tiene alguna reaccion diferente a lo que con los dos cartuchos tienes que cambiar ese cartucho que sacaste. yo tenia el mismo problema, lo cambie el cartucho de colores que era el que estaba mal y luego lo resetee y todo ok. mientras no lo cambias ese cartucho el reseteo no funciona.
Feb 24, 2012 | Office Equipment & Supplies
Quiero saber que significa el codigo P 0172, tengo problemas con las revoluciones del motor, se me apaga el motor cuando esta en baja, lo puse en la computadora y primero me *** P 0496, ya esa piesa la...
B?sicamente esto significa que un sensor de ox?geno en el banco 1 detecta una condici?n de rica (muy poco ox?geno en los gases de escape). En V6/V8/V10 motores, el Banco 1 es la parte del motor que tiene el cilindro # 1.
Nota: Este DTC es muy similar al P0175 , y, de hecho, su veh?culo puede mostrar dos c?digos al mismo tiempo.
Los s?ntomas: No m?s que probable que observa cualquier problemas de manejo, aunque puede haber s?ntomas como un fallo de encendido.
Un c?digo P0172 puede significar que uno o m?s de los siguientes ha ocurrido:
El MAF (flujo de masa de aire) del sensor est? sucio o defectuoso. Nota: El uso de filtros "aceitado" el aire puede causar que el MAF se ensucie si el filtro est? m?s aceitada. Tambi?n hay un problema con algunos veh?culos, donde los sensores MAF fuga del material de silicona para macetas utiliza para proteger los circuitos.
No puede haber una fuga de vac?o.
Podr?a haber una presi?n de combustible o un problema de entrega
Las posibles soluciones son:
Inspeccione todas las mangueras de vac?o y PCV, reemplazar si es necesario
Cleanthe MAF sensor. Consulte el manual de servicio para su ubicaci?n si necesita ayuda. Me parece que lo mejor es sacarlo y rociarlo con un limpiador de electr?nica o limpiador de frenos. Aseg?rese de que est? cuidado de no da?ar el sensor de MAF, y aseg?rese de que est? seco antes de volver a instalar
Inspeccione las tuber?as de combustible para las grietas, fugas o pellizcos
Revise la presi?n de combustible en la l?nea de combustible
Revise los inyectores de combustible, que puede estar sucio. El uso de combustibles m?s limpios de inyecci?n o hacer que una limpieza profesional / reemplazado.
Compruebe si hay una fuga de escape antes del sensor de ox?geno primero (esto es poco probable que la causa del problema, pero es posible)
Detalles adicionales a traves de este enlace: ODB Fault Codes - Codigos de Falla
Suerte.
Sep 26, 2011 | 2005 Chevrolet Colorado
Al conectar la maquina por puerto usb con sistema operativo windows 7,no carga el scaner, siempre da fallo en display de desconexion por lo que percibo no tiene controlador quisiera saber como lo obtengo...
Saludos aparentemente el problema esta es que el scanner no tiene drives para el windows 7. Te sugiero que vuelvas a la pagina de HP y trates de bajar con el sistema opertivo d Vista ya que este es el mas cercano al sistema que usas. Trata de sacar el programa en tu computadora , vuelves a instalarlo. Suerte!!!
Jan 30, 2011 | HP PSC 500 All-In-One Printer
Cuando lo cierras no suena la alarma
Si Ud. se refiere a que no suena 1 vez cuando cierra y 2 veces cuando habre es por que el alarma esta en modo de silencio, en este caso dependiendo del modelo de alarma que Ud. tenga puede ser programado desde el remoto o a su vez con el mini switch que esta ubicado debajo del tablero del automovil, logicamente que para estos pasos debera tener a mano el manual de programacion de su alarma.
Mar 11, 2010 | Vehicle Parts & Accessories
Check engine que significa ese icono
El icono del motor del cheque significa simplemente que el ordenador del coche ha identificado un problema en alguna parte dentro de uno de los muchos sistemas del coche. Para saber exactamente por qué de que la luz del motor del cheque llegó el tienes que tener el ordenador del coche escaneada. Conduce a la mayoría de cualquier tienda de piezas de automóviles o AAMCO y que van a hacer el análisis de forma gratuita. A continuación, le dirá lo que su equipo es informar a usted como un problema. Regards, Joe
PS favor y amablemente tasa de mi respuesta. Gracias.
Jan 21, 2010 | 1995 Jeep Grand Cherokee
Quisiera restaurar el monitor a como estaba de fabrica
se te a video settings y fijate que la resolucion sea la correcta. fijate que los setting de tu monitor sean los de default.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
57 people viewed this question
old marine
old marine
