Question about RTO Ho Herpa Freightliner Truck Tractor
128 15500 fault code
Engine proctection light coming on and loss of power. code high 128 15500
Engine light comes on occasionally & power is affected. Replaced Cat converter 2 yrs ago But has re-occurred Anything else could this be?
engine light on can be from either the engine or transmission as both activate the light and the loss of power is the ECM going into limp mode
have the fault codes read to determine the problem area
May 26, 2017 | Cars & Trucks
My ssangyong kyron check engine light comes on when driving and loses power. What can be the case?
run the fault codes to find the sensor that is putting the engine light on
the fault could be either engine or transmission as the light covers both
the loss of power will be the ECM putting the engine in limp mode to prevent serious damage
Dec 21, 2016 | SsangYong Cars & Trucks
High emmisions loss of power at 3000 rpm diagnostics says no fault found
You didn't mention what sort of car you have.
You can try disconnecting the electrical lead on the MAP sensor. Then give the car a test drive.
A faulty MAP can cause high emissions, erratic running and high fuel consumption.
You can also try cleaning the EGR - the exhaust gas recycler valve.
It's strange that you have no fault codes. There is no check engine light illuminated?
Mar 15, 2016 | Cars & Trucks
Reduce engine power light comes on 2005 buick lacross
The check engine light n or reduced power light comes on when the on-board computer detects a fault in engine driveability or performance, transmission control system or transmission, or the emissions system, and a fault code is set and stored in the computer. Faults that can set the check engine light can range from a vaccuum leak, engine mis-fire, low engine compression, faulty sensor such as O2 sensor or other engine sensor, hydraulic pressure loss in transmission, transmission shift solenoid, open/short in wiring harness, emission evaporative system leak, or one of over a hundred different reasons. The only way to know what set a fault code and turned the check engine light on is to have a diagnostic scanner hooked up to the on-board computer and read it for stored diagnostic fault codes. Many auto parts stores will do this service for free- (like auto zone)check with you local parts stores. If none in your area do, then you will have to take it to a shop and pay to have the computer read for stored fault codes. Without knowing the fault codes numbers, it would be irresponsible to guess as to the cause as there are hundreds of possible causes.
Nov 16, 2015 | Buick Cars & Trucks
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
Diesel hiace loss of power
Orange light mostly denotes the Malfunction Indication Lamp (MIL) or Check Engine Light (CEL) to tell the driver that there is fault in the engine electronic system. To locate the problem it need to be scanned with diagnostic computer or other wise it could also be checked by retrieving the codes manually.
Nov 26, 2013 | Toyota Cars & Trucks
Retrieve codes for 2003 road king
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector.
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
10 43 Loss of power train security status
Apr 11, 2013 | 2003 Harley Davidson FLHRCI Road King...
Volvo xc90, warning comes up ''engine service required'' then loss of power until warning goes off.
Hi.
The loss of power can be caused by a big number of different fault. A code reading would be a good first step to troubleshoot the fault.
If the check engine light comes on, then engine faults have been detected and related codes have been stored in the vehicle's computer modules. Primary DTC (trouble codes) are stored in the main computer (called ECU). Such codes can be read using an OBDII code reader connected to the socket under the dash. Here a code reader: U480 Can Bus.
A code scanning can also be performed at the dealer place or at any garage. In US it can be done for free at the nearest Autozone.
If there is no indicative codes also test the fuel pump and pressure regulator by reading fuel pressure with a gauge connected to the port on the fuel rail. Here the tool: Wilmar W80594.
Regards.
Ginko
Oct 22, 2011 | 2003 Volvo XC90
Jag xtype 2.0D 2004 Glow plug light flashing.Engine malfunction light on .No loss of power.Hhappened just after refuelling
jaguar x-type 2ltr diesel 2004 the glow plug warning light flashing, was told dirty fuel on fault code all fuel changed and filters. No problems for 20 miles untill engine was put under power on high revs went into limp mode, warning light glow plug falshing again? any ideas thanks.
Feb 09, 2011 | 2004 Jaguar X-Type
Check eng light comes on and then loss of eng power
The check engine light/service engine soon (yellow light) comes only when the computer control unit (called the PCM) senses a fault in the electronic controls of the engine and/or the emission system u will seldom feel the car engine run any different, there are about 200 possible faults that turn the light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen and Autozone parts stores do this testing for free.
Sep 25, 2010 | 1999 Ford F350 Regular Cab
RTO Ho Herpa Freightliner Truck Tractor Logo
41 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
