Question about Electrical Supplies
My clarke generator made a loud bang when starting with the pull cord
CLARKE GENERATOR 2.8 Kva 230v PETROL 6.5HP
4 Suggested Answers
SOURCE: ihave a g900 clarke generator that runs perfect,smells of petrol
Hi i have the same unit, i believe that this is just after fumes that actually smell very much like petrol. As this happens to mine as well and the cap is a very tight seal. Its very much like the smell of an old petrol lawn mower.
Do you know which way round the 240v plugs go.... for instance, which pin is positive (live) and which pin is ment to be negitive (neutral).
As you can put the plug in either way it just seems wrong??
POST SOLUTION HERE THANX
Posted on Aug 18, 2009
harlan301
  • 205 Answers
SOURCE: I'm looking for an operation manual for a
you can check the uk there a link there. also check your capacitor
Posted on Oct 13, 2009
  • 142 Answers
SOURCE: the starter cord pulled out but will not go back
The pulling back spring is broken or loose.
Posted on Jun 14, 2010
D voltmeter of my 3.5KVA generator stays @ 230v while it is running on bulbs, tv & fan but drops to zero (and everything goes off) once I put 'on' my refrigerator. It returns to 230v if I put it 'off'
adjust the governor on the motor
or the generator cant take the max load anymore
do your
sums again must be close to the 3.5 kva with that lot on
Apr 29, 2017 | Refrigerators
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
Jan 19, 2015 | Electrical Supplies
Where can I purchase a replacement petrol tap for my Rockworth 2.4/8 kva generator - approx 5 years old
Try here. Click Enter Parts System, then select Rockworth from the list on the left. They may be able to help.
Generator Guru
Dec 18, 2014 | Electrical Supplies
Just bought a s8000 3phase, straight petrol pramac generator, can I run my large 3 phase mixer and a 240v hand whisk at the same time?
Look at the name plate ratings on your devices, they should give you the KVA load of the device. Add all of these up. If the load exceeds the output of the generator, then it wont work
Sep 17, 2014 | Electrical Supplies
I already broke one recoil starter assembly on my Astra Korea 3 kVA generator. I can start the generator, but with great effort. It takes about 6-8 pulls, and there's so much resistance that I can actually...
The easiest test to run on the generator is to remove the spark plug and see if it pulls easier. If it does then it is a compression problem. I doubt that is the case. If it does not then you need to take the generator off the motor and see if it still pulls hard.
Jun 20, 2014 | Electrical Supplies
Generator back firing from inlet manafold
Your symptoms are from running lean. Foam air filters put debris in carb jets. Check all the carb passageways and jets. Always start with a new plug.
Nov 29, 2013 | Electrical Supplies
I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Ihave a g900 clarke generator that runs perfect,smells of petrol
Mar 31, 2009 | Electrical Supplies
Electrical Supplies Logo
13 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
