Question about Electrical Supplies
My clarke generator made a loud bang when pulling the pull cord
CLARKE GENERATOR 2.8 Kva 230v PETROL 6.5HP
  • 10865 Answers
SOURCE: pull cord
Yes. Most any hardware store can sell you a new cord. If you want to replace both the cord and the pull mechanism you may have to contact a dealer.
Posted on Jan 26, 2009
SOURCE: ihave a g900 clarke generator that runs perfect,smells of petrol
Hi i have the same unit, i believe that this is just after fumes that actually smell very much like petrol. As this happens to mine as well and the cap is a very tight seal. Its very much like the smell of an old petrol lawn mower.
Do you know which way round the 240v plugs go.... for instance, which pin is positive (live) and which pin is ment to be negitive (neutral).
As you can put the plug in either way it just seems wrong??
POST SOLUTION HERE THANX
Posted on Aug 18, 2009
dmftrucker
  • 1922 Answers
SOURCE: Unable to pull starter cord at all
pour some gas/oil mixture down sparkplug hole and let it soak and see if the rings are carbon blocked
Posted on Oct 07, 2009
harlan301
  • 205 Answers
SOURCE: I'm looking for an operation manual for a
you can check the uk there a link there. also check your capacitor
Posted on Oct 13, 2009
  • 342 Answers
SOURCE: I broke the pull cord on my generator; how do I
you should remove the housing usually 4 bolts
dont remove anything else then look at the pully and remove the old chord tie a knot in the new chord and slot it into the hole on the pulley
you should then see a notch in the edge of the pulley this is for the chord to sit in while you turn the pully enough times to tension the recoil spring once tensioned enough so that it recoils all the chord slot the chord through the hole in the outer casing through the pull hande and knot it job done then refit
Posted on May 10, 2010
I need the wire diagram for Katolight D350FRV4 432 kVA Gen
Have you tried google as there are lots of manuals available online if you search for them
Jan 07, 2018 | Electrical Supplies
What is the general specification of Genset 20kv?
Generally 20 Kva power generator can produce more power. The voltage used in this 20 kva generator is 3 phase with frequency 50 Hz. 20 kva generator engine is already very enough for use on buildings that require large electrical power or public places such as shops. According to me HARGEN provides the best high quality genset.
To fill the fuel tank to the full required 62 liters of fuel in order to use this 20 kva generator engine with more leverage.
20 kva generator engine is also issued a noise that can reach 61.7 db or can be heard up to a distance of 7 meters away from where this generator is located.
Sep 11, 2017 | Cars & Trucks
D voltmeter of my 3.5KVA generator stays @ 230v while it is running on bulbs, tv & fan but drops to zero (and everything goes off) once I put 'on' my refrigerator. It returns to 230v if I put it 'off'
adjust the governor on the motor
or the generator cant take the max load anymore
do your
sums again must be close to the 3.5 kva with that lot on
Apr 29, 2017 | Refrigerators
I already broke one recoil starter assembly on my Astra Korea 3 kVA generator. I can start the generator, but with great effort. It takes about 6-8 pulls, and there's so much resistance that I can actually...
The easiest test to run on the generator is to remove the spark plug and see if it pulls easier. If it does then it is a compression problem. I doubt that is the case. If it does not then you need to take the generator off the motor and see if it still pulls hard.
Jun 20, 2014 | Electrical Supplies
I just took delivery of a new FUJIMICRO - 5600p 13 hp/7.5 kva/5.2 W petrol Inverter generator. I does not run, support tells me that manufacturer made an error and fuekl should be diesel and not unleaded,...
yes
remove the tank and drain into a container
I am suspicious because you specifically that it is a 13 hp /7.5 kva/5.2 watt PETROL inverter generator
where did you get that information if not from the specifics plate attached to the genset
look on the engine
if it has a carby it is petrol
if it has a diesel pump it will be diesel
Dec 22, 2017 | Computers & Internet
I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Ihave a g900 clarke generator that runs perfect,smells of petrol
Mar 31, 2009 | Electrical Supplies
Broken starter cord to petrol generater
You have to tighten the spring inside where the cord goes. The pull cord pulls on leverage by using a clock like spring like a lawn mower. You have to take it all the way apart. The cord part. To get to the spring.
It is strange answering this in a computer section. I answer computer questions and this is certainly not a computer question. Unless you have a wind up computer. Now I have heard of these. Where are you located, if this is a wind up computer.
Jun 03, 2008 | Computers & Internet
Electrical Supplies Logo
27 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
