Question about Candy DFI Plan Built-In Dishwasher
My Candy CDF8 dishwasher does not heat water. I've replaced the heating element and the thermistor, the safety switch seems ok; any ideas?
3 Suggested Answers
  • 1462 Answers
SOURCE: candy cd623 uk dishwasher water not heating up
not familiar with model. element can be inside cabinet in which case it will be obvious or may be in a cylinder heater mounted in the base. suspect stats as well or possibly the module
Posted on Mar 20, 2007
ercupa190
  • 12223 Answers
SOURCE: Candy DWI 160 dishwasher water not heating.
the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle.
Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
Posted on May 09, 2012
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Water heating time out or fault
The dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element.
Check water heating element wiring
Check wiring to main control module
Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
E3 - Missing heating of the water.
Could be:
· Clogged filtering plate.
· Defective heating element.
· Defective wiring (open circuit, leads
off place or loose).
· Defective electronic control board.
You have already changed all major electrical components energized during the heating phase. But do not forget that failures sometimes could be mechanical. For example: failure could be in hydraulic circuit of pressure switch, sometimes hydraulic circuit can lost air pressure. Another note would be that your dishwasher have NTC thermistor which every second gives information about temperature to electronic than electronic controlled heating element by a relay.
In order to heating element come under the voltage is necessary to fulfill a couple of requirements. Microswitch on the door in the closed position, the pressure switch in position 11-13 (full position , level of water) and the main switch is turned on.
24881895-svalokc2bmago0zdlfvpjh25-3-2.png Dado
May 08, 2012 | Candy Dishwashers
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Dishwasher won't heat water. I can't find where to
not a common problem,remove the rear panel at the bottom the element sits in front of the motor,check to see if the element is open circut,the things that can cause this fault are element,wiring,pcb,thermistor or fat buildup in the pressure chamber under the filter.hope this helps
May 01, 2010 | Asko 24 in. D3350 Dishwasher
The washer is doing a full cycle but it is not heating the water. The element seems ok and measures 32 Ohms resitence. any ideas?
Thermostat, sensor, any safety switches, check continuity to, from, controller. relay? The micro-controller?
Feb 16, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Water is not heating in dishwasher
On the BDW13 Baumatic dishwasher I had the same problem, as I fix gas boilers I ohm tested the heating element, which was ok, I then tipped the machine on its side and took the bottom off, be careful, always disconnect the electric and water, underneath there are two thermostats, I know them as thermistors on a boiler, they screw into the brackets that hold the element in place inside the dishwasher, I unscrewed them after removing the wire connectors(pull off) I then ohm tested them and found one was an open circuit(faulty) the problem is, the one that was faulty is a non-self-resetting type, which means it has to be replaced once it has tripped, which is a real pain, the other one resets after it has cooled down.
Aug 18, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Candy cd623 uk dishwasher water not heating up
Mar 19, 2007 | Candy 24 in. CD622 Free-standing...
Candy DFI Plan Built-In Dishwasher Logo
154 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Dado
Tom Chichester
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
