Question about HP DesignJet 1050c InkJet Printer
Error code 09A008 007A07B2
Call hp
  • Gary
    Gary Mar 16, 2014
    EIO Accessories (EIO Card/Hard Disk Drive) Error EIO Card is either the network card, or a hard drive that slides into a slot in the back of the plotter...one has gone bad. Remove them both and see if the error goes away. If it does, reinstall one of them and power back on. If the error returns, you know what part needs replaced !
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Tip
Here is information about HP Laser printer error Codes
This site:<br /> <br /> <a href="http://www.all-laser.com/aerror-code/">http://www.all-laser.com/aerror-code/</a><br /> <br /> <a href="http://printertechs.com/tech/error-codes/error-codes-index.php">http://printertechs.com/tech/error-codes/error-codes-index.php</a><br /> <br /> <a href="http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/HP-error-code/td-p/31465">http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/HP-error-code/td-p/31465</a><br /> <br /> <a href="http://www.fixyourownprinter.com/reference/errorcodes/hp">http://www.fixyourownprinter.com/reference/errorcodes/hp</a><br /> <br /> <br /> Hope this sites will help you.
on Mar 15, 2011 | Office Equipment & Supplies
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
What does error code 168 mean?
what make and model printer is it?
Feb 14, 2016 | Office Equipment & Supplies
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
Hp error code for compaq presario code 1002
http://h30434.www3.hp.com/t5/Operating-systems-and-software/Recovery-Error-Code-1002/m-p/11366
Jan 21, 2010 | Computers & Internet
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
