Question about Electronics - Others
Clock on the alarm clock app is reading the wrong time even though time on the iPod is set correctly
Just bought product and initially everything worked fine but now the alarm clock time on the app is wrong even tho the iPod time and the time on the dock are correct. Have tried to find way of changing manually but to no avail. Reset iPod time several times manually and removed and reinstalled the app again to same results?
    Sergeant:
  • 355 Answers
Possibly wrong time zone set on app?
Posted on Dec 03, 2017
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Posted on Nov 30, 2008
SOURCE: I can not figure out
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Posted on Jan 05, 2009
SOURCE: sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Posted on Mar 08, 2009
SOURCE: tdk islim alarm setting
Here is the manual for the TDK iSlim...
http://www.tdk-media.com.sg/sg/products/peripherals/manual/iSLIM.pdf
Cheers,
Fi
Posted on Mar 17, 2009
SOURCE: HSD128A projection clock came with chinese instructions
Here is the PDF of instructions. http://www.tinxi.com/download/88028_en.pdf
Posted on Jun 16, 2009
Aside from the mini alarm clock for iPhones and iPads, can anyone recommend any good "bedside" apps for my new iPhone?
There areapps for everything!! Check out this slideshow that highlights some of the appsyou can get. It seems to cover everything from sounds to lull you to sleep toweather checks worldwide. Have fun.http://www.pcworld.com/article/239378/top_10_bedside_apps_for_ipad_and_iphone.html
Jul 23, 2012 | Memorex 02169 Ipod iphone Mini Alarm Clock
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
Just purchased, didn't have any instructions in box. How do I set time and alarm? Thanks
Clock: With the radio off, press the Clock Set button, then the Memory button. The time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Alarm: With the radio off, press the Alarm Set button, then the Memory button. The alarm time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Sep 19, 2010 | Memorex MI4019BLK Alarm Clock Clock Radio...
How do you set the alarm clock?
Sep 13, 2010 | Memorex MI4019-PNK Alarm Clock for iPod -...
Ihome--ih8,
I got the iH8 as a present everything works fine except for the ipod alarm. the unit will play my music when i press the play ipod button, and recognizes its plugged in, but when i set the ipod alarm, without taking out the ipod or anything, it doesnt go off with my music, it just buzzes. Idont think it is the ipod because i have updated the software on the ipod and have even tried 3 different ipods with the iH8. i have had the iH8 for about 2 weeks and set it nearly every day, and out of all those times it has gone off with my music only 3 times. How do i get it to work every time!??
Jul 08, 2010 | iHome Ih8 Dual Alarm Clock Radio For Ipod...
I don't know how to make the Ipod go dark after it is on the clok
first set then alarm. then set your ipod lock time to 1 min. you can fine it on your ipod setting. hope i help you.
Jan 11, 2010 | Digital Products International Clok Smooth...
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Nov 12, 2009 | Digital Products International ILIVE...
Alarm clock and time w/ clok smooth ipod system
Setting the clock
Setting the Alarms
Nov 28, 2008 | Digital Products International Clok Smooth...
RCA RP5420B 2Band AM/FM Clock Radio
At the top of the clock, there is four positions for the slider. The first is shown as a key, which I assume is the automatic time setting mode. The second is Wake 1, the third is Wake 2 and all the way to the right is a manual time setting mode. If you slide it all the way to the right, you can set the time, then either keep it in that mode or return it back to automatic mode. Either way, you now have the correct time displayed.
Jul 04, 2008 | RCA RP5420 Clock Radio
Equity 44100 clock radio problem
Hold the Alarm Set button down for about 5-7 seconds. The year will flash. Skip the year and date by pressing Alarm Set a couple times until the time is displayed. Use the Up and Down to change, then press Alarm Set one more time to save it. This clock is ****, by the way. I run into them in hotels and it makes me nuts as well. Very non-intuitive.
On the time lost issue...there is a button battery (CR2032) in a compartment underneath. That battery keeps the internal time so when the clock is plugged in, it "instantly" sets the time. Problem is, if the internal time is set wrong, then it instantly sets the wrong display time when it it plugged in. See procedure above to correct that.
Jun 10, 2008 | Equity Time USA Sky Scan 44100 Clock Radio
Electronics - Others Logo
109 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
