Question about Smeg DWI614 Built-in Dishwasher
Replace dwi614 door hinge
Chane door hinge
Why is door still open at top after replacing door hinges on Whirlpool WFE510S0AW0
Well, I assume you have the door hinge clips in the right position,
and the door is seated properly with that 2mm slot that sits on the hinge receivers. If hinges are replaced, then it must be hinge receivers.If the door is crooked, moving the hinge receiver will align the door. Besides hinge receivers should be replaced first, before the hinges, that in my experience rarely break
I dont like the bent twisted story. I bet the little plastic U-roller in the hinge receiver is worn down or cracked. Fix is to replace the hinge receiver (a secondhand one is in plentiful supply) - or find a look alike roller and fit it. Cord pully's at the local hardware store may fit, window slider tracks, or even coins with a small 1 inch by 4mm bolt as an axle will do the trick.
Still not sure. Remove the dorr using instructions, and set aside.
Remove hinge receivers from each side. Are the little wheels in there good, or wobly, worn of missing?
Problem Fixed
May 22, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
Constant drain and beeping even with the door open!
Float switch on all times, try to check the float freely going up and down, or there is water accumulated at the float. good luck
Mar 15, 2014 | Smeg DWI614 Built-in Dishwasher
Car door is sagging
Take a good look at the door hinges. Often, there will be replaceable bronze bushing inserts in the hinges, and the hinge pins are also prone to wear, especially if the recommended lubrication is not done.
If the bushings and/or pins are not replaceable and the wear is in the hinges, the hinges willl need to be replaced.
Other possible causes are loose hinge mounting fasteners, failure of the door or "A" pillar (for front doors) at the hinge mounting location(s) due to rust or physical damage, and (of course) collision damage to the door or door frame.
Oct 04, 2012 | Toyota Celica Cars & Trucks
DWI614: Fault: Switch On - initially displays all characters, then displays P0 shortly followed by 2 beeps! Pressing the 'P' button has no effect.
Just had this problem today. Went away after tightening edge-connector plugs on circuit board. Had previously tested out push-buttons with meter and were ok.
Jun 01, 2011 | Smeg DWI614 Built-in Dishwasher
My doors have fallin and now i have to lift6 up on the door with the window down to close it
Sounds like the door hinges are worn. Determine if it is the hinges or the hinge pin that is worn. It it is only the pins, which is unlikely, you can just replace these, if it is the hinges, the complete hinges will have to be replaced.
Mar 19, 2011 | 1997 Lincoln Town Car
I have a 1995 dodge dakota. I need to replace driver side door. Need to know how to take door off properly. Need diagram or something. HELP.
Removal & Installation
  1. Matchmark the hinge-to-body and hinge-to-door locations. Support the door either on jackstands or have somebody hold it for you.
  2. Remove the lower hinge-to-door bolts.
  3. Remove the upper hinge-to-door bolts and lift the door off the hinges.
Details of a common door assembly-Dakota shown
Click to Enlarge
To install:
  1. If the hinges are being replaced, remove them from the door pillar.
  2. Install the door and hinges with the bolts finger-tight.
View of the door hinges-1994-96 Pick-ups
Oct 23, 2010 | 1995 Dodge Dakota
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Bottom door hinge replacement easiest way?
Hinge, Door Removal and Installation
  1. NOTE: A second person is required if the Flexi-Work Table 156-00070 is not available.
    Support the front door (20124) using Rotunda Flexi-Work Table 156-00070 or equivalent.
  1. Mark the location of the front door upper hinge (22800) and front door lower hinge on the front door and body.
  1. Remove the front door hinge-to-body retaining bolts.
  1. Remove the front door hinge-to-door retaining bolts and remove the front door upper hinge and front door lower hinge.
  1. To install, position the front door upper hinge and front door lower hinge to the front door and body. Install the retaining bolts. Tighten to 25-35 Nm (18-26 lb-ft).
  1. Adjust the front door and front door upper hinge and front door lower hinge as outlined, and remove the support.
Jul 01, 2009 | 1995 Ford Thunderbird
Smeg DWI614 Built-in Dishwasher Logo
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
