ML-2165 reset chip free
SOURCE: how to solve samsung printor
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
SOURCE: we have all printer reset software of Samsung and Xerox and sell each software with price 12$:
Samsung CLP : 320 ' 320K ' 325 ' 325W version : 19f,34f,36f.
Reset Samsung CLP : 620ND version: 45f,50f.
Reset Samsung CLX : 3170 ' 3170FN ' 3175 ' 3175FN '3175FW version: 64f.
Reset Samsung CLX : 3180 ' 3185 version 22f,35f.
Reset Samsung CLX : 3180FN ' 3185N ' 3185FN ' 3185FW version: 24f,35f,36f.
Reset Samsung ML: 1640 ' 1641 ' 1645 version: 60f,83f,93f,96f (FREE)
Reset Samsung ML: 1660 ' 1665 ' 1665K ' 1667 version 30f (FREE)
Reset Samsung ML: 1660 ' 1665 ' 1665K ' 1667 version 34f.
Reset Samsung ML: 1670 ' 1675 ' 1677 ' 1671 version 0.4f,0.7f
Reset Samsung ML: 1860 ' 1861 ' 1865 ' 1866 ' 1867 version 18f,19f
Reset Samsung ML: 1910 ' 1911 ' 1915 ' 1915k ' 1916 version 77f,82f (FREE)
Reset Samsung ML: 2240 ' 2241 ' 2245
Sua may in ' Do muc may in ' do muc
SOURCE: where can i download the driver for samsung printer ml 2165
Samsung ML-2165 Printer driver and software for Microsoft Windows, Linux and Macintosh.
http://www.samsungdrivers.net/samsung-ml-2165-driver/
