Konzert 502 one channel is weak and when i turn on xbass switch it was trip off
4 Suggested Answers
alxz
  • 89 Answers
SOURCE: I have a konzert amplifier av-502 that has two
Is it the resistors near the relay? that would be 10 ohms. You may replace it with a higher wattage (like say 5 watts)
Posted on Oct 05, 2010
dunnbiker
  • 8546 Answers
SOURCE: Konzert AV502a (500watts per channel)
Your listening habits should not have you pushing the volume level so high that the amplifier will distort, as it is DIRTY wattage that kills speakers. A more powerful amp will distort less if pushed to a given loudness.
BTW: the specs for the amp and speakers are not really what they claim. Since the same company made them the numbers are probably equally wrong. Don't sweat it and don't turn it up so loud that it distorts.
Posted on Dec 29, 2010
jdvillanueva
  • 2098 Answers
SOURCE: how can i upgrade my av 302 to becomes best as
upgrade your 302 to 502 need to replaced the toroid transformer, set of output amplifier, set of electrolytic capacitor.
Purchasing of these parts one-by-one is much expensive rather that you buy a brad new Konzert AV-502. Also upgrading the unit is quite tech and need a lot of experienced in electronics.
Hope that it may help you.
Have a nice day.
JDVillanueva
Posted on Jan 31, 2011
Konzert amplifier av 502 schematic
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electronicshelponline.blogspot.com
Apr 11, 2014 | Audio Players & Recorders
What would be the probable cause of my konzert amplifier av-502 after replacing 2 power transistors npn & pnp in the left channel, the sound is distorted. i'ved checked the voltage across the spea
Check the bias resistors. They can burn out when power amp transistors fail. They will be very near to those two replacements. You can compare any parts using the right channel as a good. Readings and voltage measurements should be the same for both channels. Also the look of the parts. If a resistor is off-colour in the left, but not in the right you know something is up.
Jul 02, 2013 | Audio Players & Recorders
Konzert 502
Change pre drivers and drivers also change outputs emitter resistors, 0.33, 0.22, or 0.47 ect
Jul 01, 2013 | Audio Players & Recorders
Just asking for a right speakers for konzert 502a
What actually is Right is for you to decide:
These will be dependent to what you intend to use.
If these unit will be used for Karaoke , suggestion could be
using Single 15" Konzert Speakers for each channel or
Dual 12" Konzert Speakers for each channel.
But if you intend to use it in a small room , you can visit the
showroom in which speakers are connected to it, to have your
final decision.What may be best for others may not be the one
you choose.Listen and feel what you like .
Have a nice day!
Nov 03, 2012 | Audio Players & Recorders
I have a konzert 302, just the other day I was wondering why the left speaker sound is disorted and very scratchy. I Thought it was only my speakers but I check and found out it was from the left chan
If you intend to DIY , check for possible cold solder joints,
leaky transistors , changed-value resistor.
Upgrade to 502 it is better than the one you have.
Aug 02, 2012 | Audio Players & Recorders
What is the specs of konzert av-502 amplifier
input voltage: 220vac
500 watts /channel
5 channel output
pro logic surround decoder
single output digital delay
w/ karaoke function
Aug 08, 2011 | Car Audio & Video
How can i upgrade my av 302 to becomes best as konzert av-502
Have a nice day.
JDVillanueva
Jan 31, 2011 | Audio Players & Recorders
I have a konzert amplifier av-502 that has two burnt resistor r130r and r130l. could you please let me know the value of the said resistor thank you very much.
Aug 02, 2010 | Audio Players & Recorders
MTX 502 2 chanel amp Pre amp problem?
Unless your amp is 1 (one) ohm stable then you may have fried it. When you attach a 2 ohm load across a bridged amp then you have effectivly placed each output channel on a 1 ohm load. Not a good thing in most cases. Try hooking up ONE speaker on one channel and one input to that one channel one at a time. Then switch the speaker/input to the other channel and see if you can get either or both channels to work independently. Needless to say you must turn the amp off before you make ANY change in the wiring.
Jun 25, 2007 | MTX Thunder 2-Channel Amplifier 502 Car...
44 people viewed this question
 Grubhead
Grubhead
