Question about Samsung N Computers & Internet
Auto power on ,no off
Auto power on,
Power window
Sounds like a passenger switch malfunction.
Sep 08, 2013 | 2009 Mazda CX-9
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Tip
How to enter Factory settings on GNR TS700 (Black/Silver) 17" LCD monitor
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
on Dec 31, 2009 | Computers & Internet
Auto power shut off - how can I disable
Enter in the users mode and reset the auto power mode.
Feb 07, 2012 | Sharp Office Equipment & Supplies
Power save mode
Enter in the User programs and select the auto power shut OFF setting.Use this setting to enable or disable auto power shut OFF,press 0 to OFF or 1 to ON.The program name is auto power shut off setting and the program number is 5.
Nov 19, 2009 | Sharp AR-M205 Copier
Leak in the power steering system.
SOUND LIKE POWER STEERING PRESSURE HOSE LEAKING.COPPER TUBING IS TOO SOFT METAL FOR POWER STEERING AND BRAKES SYSTEM.BUY A PRESSURE HOSE AT ANY AUTO PARTS PLACES LIKE AUTO ZONE OR ADVANCE AUTO PARTS. PRESSURE HOSE SHOULD HAVE O-RING COME WITH IT.
Nov 12, 2009 | 1991 Pontiac 6000
On the Sony DSC-H7 camera can you disable the auto power off? If not does the use of an external power supply disable it? Thanks
The auto power off function that operates if the camera is not used for about 3 minutes, when operating on battery power, cannot be deactivated.
When using the camera the camera powered from the Sony AC-LS5 AC mains adapter, or with the Sony DCC-L1, DC power adapter, the camera auto power function is deactivated whilst the camera is connected to the power supply.
Jun 17, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Camera freezes when changed from Auto > Scene
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain
drrjain3@rediffmail.com
Apr 15, 2008 | Nikon Coolpix S3 Digital Camera
Auto Power Off function DiMAGE E223
Yes, the auto power save functions to save power. The camera shuts itself off after 3 minutes after the last operation
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
Auto Power Off function?
To conserve battery power, the camera will shut down if an operation is not made within 3 minutes (default setting). The auto-power-off period can be changed in the setup mode to 1 min., 10 min. or 30 min. at user's option. When using the AC adapter, the auto-power-off period is set at 30 minutes.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Computers & Internet Logo
24 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
