Question about Caterpillar Electrical Supplies
Spare fault sp 1 upon start - caterpillar 3516b generator
2 Suggested Answers
rwooley
  • 100 Answers
SOURCE: my problem is voltage fluctuation, after starting generator the voltage is 380v and become 150v then goes up to 410v
I am sure the problem is the adjustment of the voltage regulator.
There are 3or4 small adjustable "pots" on the circuit board of the regulator.
You must connect an analoge volt meter to the output of the generator for this adjustment. Adigital will not work in this case. You will need to adjust the "IR" compensation pot as necessary to stabalize the voltage. This adjustment will surely change the voltage also. As you change the IR you will need to change the voltage too.
Let us know if you need more help.You may need to get the info sheet for your regulator if the pots are not cleasly marked.
Robert
Posted on May 16, 2012
I have cat D399 wont start? when i crank it with air starter its run as long i hold the starter on whehn release the starter botton stopped?
if i remember right there is a solenoid valve on them when starting it has to be down for engine to start. if it fails it dont get the pressure needed to start. when engine is running and warmed up it opens. cannot remember were it is but I used to have one a long long time ago. and it was this fault.
Jan 02, 2014 | Caterpillar D399 Generator Drive Engine
Diagnostic code codes
if its new why in the hell are you here asking questions. I'd be giving CAT an earfull !!!
Dec 26, 2013 | Caterpillar NEW 3512C Petroleum Generator...
Hrabour pushing Tug, fitted with 2 Main engines 3516 b, One is non operationalsince last 2 Months Should have taken any special precautions except turning through turning gear. The other one starts daily...
White smoke on a diesel when it just starts indicates low compression. Most likely excessive ring gap until some heat is generated to expand the block and pistons.. It's overhaul time.
Oct 31, 2013 | Caterpillar 3516B DITA Marine Propulsion...
My caterpillar gen electric gen set shown a fault alarm and emergency shut off after its not starting no any signal
What fault alarm did it indicate? No start signal at all normally means a safety lockout, is it cranking at all? Can you give me more details please
Oct 23, 2013 | Caterpillar 1984 3208 Generator Set 75,...
Fuel leak on powercraft 720 generator
The fuel hoses can leak if bent in an unreasonable fashion during installation or upon completion of installation.
Oct 04, 2012 | Office Equipment & Supplies
I have a 3516B model, the problem is: at idle or low load (200-300 kw) the engine runs fine with little or no visible exhaust smoke but while ramping up to desired load (1200kw) the exhaust smoke turns...
How often has it run at less than 30% capacity? It maybe wetstacked see if it burns off under a laod bank first at 75% nameplate rated EKW. Then check each injector sparay pattern, sounds like an injector, or the timing is off also, since a top end was done
Sep 17, 2011 | Caterpillar Electrical Supplies
Dears:Sirs We have caterpillar Gen Set 3516B to reduce the consumption of diesel we added boi fuel to the system (using gas mixed with inlet air) this reduced it by 30-40% ,but it lead to lube oil...
I am not sure what Bio fuel conversion system you ahve added, I assume it is to the air intake system. Before you did that, check the compression on each cylinder as incorrect set up bio fuel after market gas kits can cause overheating of the fuel rail system. Also the system maybe running too rich now with the injection of gas.
Aug 15, 2011 | Caterpillar Electrical Supplies
My CAT generator burned up another voltage regulator. Do you know what could be the problem?
If the generator runs for a period of time and all works well then it burns up, you need to make sure that the unit is NOT been shut down under load, check for rotating short on the rotor. May ohm ok when stationary but upon centrifugal force can cause a short. Check the exciter windings for shorts and correct resistance, as well as the obvious chaffed wiring
May 14, 2011 | Caterpillar Electrical Supplies
We just relocated our cat gen, we start it up but does not generate voltage and goes instantly to cooldown mode.
Which model CAT???? No voltage check the AVR for exciter output first, it may be a control issue shutting down the AVR, so before replacing check for fault sensor input
Oct 06, 2010 | Caterpillar Electrical Supplies
Electrical Supplies Logo
52 people viewed this question
Top Caterpillar Electrical Supplies Experts
gbob59
Lawrence Oravetz
ray gallant
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
